Colin Mitchell
- Aug 31, 2014
- 1,416
- Joined
- Aug 31, 2014
- Messages
- 1,416
What transistors are you using?
This is a schematic with the read values of current using the R7 100R resistor, what i'm not understanding, is how can the regulator only be passing 100mA with a 25R resistor ? And in the original drawing its 860mA or a bit over that. As a 25R resistor is 1/4 of the original R7 value, would the current not be 215mA Or there about's with the lower value resistor.
I think both you and several responders to this thread are in need of an adjustment in perceiving how a BJT transistor works. First of all, a BJT is not a current amplifier, beta is not the current amplification factor, and you do not control or drive the transistor with current. Without going into the physics of the BJT, let me say that a BJT is a transconductance amplifier. That means that a voltage applied to the base-emitter will control the collector current. The beta is a measure of the "waste" current that is present at the base terminal when the transistor is biased in the active region. It is proportional to the collector within limits, but it does not control the collector current. Now, a BJT can be part of a circuit that amplifies current, but a BJT by itself cannot be called a current amplifier.Recently i've built a couple of voltage regulator transistor emitter follower circuits, using a single TIP2955, and two TIP2955 transistors. Curiosity has led me to a more powerful transistor.
At this stage i am unsure as its gain minimum is quoted at 1K or 1000mA, its power rating is a lot more than the TIP2955 which i have had really good results with building these two 12 volt power supplys.
The transistor i am looking at, or hoping i can use is the following: Type MJ11015 PNP, VCB VMAX 120, IC mA MAX 30, PTOT mA MAX 200W, HFE MIN IC mA MAX 1K@20A, pin out is quoted as 23A epitaxial TO3 package. I was hoping some one could help me through pitfalls if any of using this transistor, i have posted the schematic below. Where TIP2955 transistors are i wanted to use the following transistor above. i would be very grateful if anyone can help me with this. Many thanks. View attachment 25101
