By using voltmeter. How to measure the voltage of collector and emitter. Vbc is the collector voltage and Vbe is the emitter voltage? And how should my voltmeter place? Sorry for the silly question
The circuit will have a ground connected to many stages.
Measure the voltage between ground and emitter.
Measure the voltage between ground and base.
Measure the voltage between ground and collector.
Some subtraction will give the voltages required.
With an npn transistor, the voltages relative to ground will rise from emitter to base to collector and there is likely to be about 0.6V emitter/base.
NpnNPN or PNP?
