I have a few questions about transistors, so here we go:
How can you tell how much current must flow between base-emitter to allow current to flow collector-emitter??
How can you tell which connector on a transistor is the emitter?
When a transistor gets a small current running through the base-emitter, which then allows current to flow collector-emitter, does the current through the base-emitter get cut off? Or does it keep flowing in tiny amounts?
One last one: If a transistor has a current flowing base-emitter which then allows current to flow collector-emitter, if the base-emitter current is turned off (by a switch or something) does the collector-emitter current turn off too? Or does it just need a kick start to get going then nothing can stop it except a switch or broken circuit?
I'm very sorry if my questions are unclear, I'm not very good at describing things ;D
Again, thanks for all the help, you guys are life savers (no not the candy 8) )
