Tri-level composite signal from microcontroller
epicedium
Jun 29, 2017
3
What is the easiest way to generate this pulse from a microcontroller running at 3v3? I have IO pins and PWMs available.
https://en.wikipedia.org/wiki/Tri-level_sync
I haven't dealt with negative voltages before, and I'm not that familiar with analogue electronics (other than simple opamp circuits). My first instinct is to generate -3v3 (somehow?) then use 2 or 3 microcontroller pins to switch 2/3 mosfets or transistors with resistors dividing voltage, but I do wonder if there's a better/ simpler way.
It doesn't seem possible/appropriate to create a virtual ground unfortunately, as the composite signals go out over BNC using chassis ground.
duke37
Jan 9, 2011
5,364
The wikipedia article says there is no DC, perhaps a capacitor in the line would be sufficient.
There are integrated circuits which can give a low current negative supply, I have never used one.
Alec_t
Jul 7, 2015
3,820
The opamp would need a dual-polarity supply if you want it to put out a negative-going pulse.
Alec_t
Jul 7, 2015
3,820
Duke suggested a cap. Here's a sim. Good enough for your needs?
epicedium
Jun 29, 2017
3
Alec_t, Duke- the cap, it may well be acceptable, yes! I'll simulate it into a 75Ohm load and experiment- my experience with AC is pretty minimal so I don't really grasp how it works. I assume that I could clamp the spike with diodes and that the magnitude and duration of the spike are a product of the capacitance and load. I'll report back once I've had a play around. Thanks!
