Trouble with 17" ADI monitor: red/pink tint over screen
  • Thread starter Andrew Bestfrenn
  • Start date
Andrew Bestfrenn
I have an ADI Microscan 17" 1998
I bought this monitor yesterday, and was told that it took a while to
warm up.
When I turned it on, it looked pink for about 20 or 30 seconds and
then
went to a normal color . It worked perfectly all day after that.
I went out in the afternoon and when I got back at 9 pm the monitor
had turned pink again. I tried turning it off and restarting it,
but it is still pink. It be just that the cable needs to be removed
and replaced or I may have to
adjust the green gun setting inside the monitor.
If you have any experience with fixing a similar problem?
Jerry G.
It sounds like the tube is getting soft, or there are some components
failing most likely in the green channel.
Why would you buy a used monitor with a possible known problem??? These can
end up being not worth servicing.
Greetings,
Jerry Greenberg GLG Technologies GLG
WebPage http://www.zoom-one.com
Electronics http://www.zoom-one.com/electron.htm
warm up.
then
