TV aerial signal meter/spectrum analyser
David C. Partridge
Anyone know where I can rent one for a day at a reasonable price.
Based near Coventry/Warwick/Leamington in the UK.
Aerial fitters charging 3* cost for parts and GBP75 per hour and GBP4 per
meter of CT/100 coax is crazy. If I can rent a meter for a day I can do
the whole job for less than these thieves wanted to charge just for the
aerial (Televes Dat75).
I may even manage to do without replacing the existing aerial if an
alignment tweak will actually bring in Mux/A from Sutton Coldfield above the
noise. Strangely BBC1 (on adjacent channel) is poor too.
David C. Partridge
Because that wouldn't allow me to see the change in the channel 47 digital
signal as I moved the aerial.
Arfa Daily
the
I wonder why it is that you think that qualified aerial riggers, who have
invested the considerable amounts of money that they have in test equipment
( have you any idea how much a digital specification spec anny costs ? ),
ladders, a van, public liability insurance and all the rest of it, are
robbers and thieves ?
Also, what makes you think that you can sort the problem that you have ?
Just looking for signal strength readings on DTTV is not a satisfactory way
of getting the best results. As you turn for maximum signal, you may well be
peaking up on a reflection, and the BER could be going out of the window. If
the reception is at all marginal where you are, then you will almost
certainly not get away with an existing aerial, no matter what the BBC would
have you believe with their self - serving adverts. The Dat75 aerial which
you quote is a fairly special broadband antenna specifically designed for
DTTV use, and will not be cheap.
I agree that £4 / m seems expensive for CT100, but I would be surprised if
any reputable rigger was charging that much for it.
If you have to have a replacement aerial fitted for DTTV reception, you can
expect to pay in the region of £150. Personally, if you add up the cost of
the parts, then take into consideration the cost of your time whilst you're
doing the job, then how much money you're going to lose by being off work
with a broken leg from falling off the roof, then I think that this is a
very reasonable amount.
Leave it to the professionals - you'll be glad you did in the end ...
Arfa
