TV set - I have broken it
kellogs
Jan 7, 2014
94
I have unscrewed its back cover, done my work with it (TV working ok), then placed the cover and screwed it back in again; there was some rocking involved in the process. TV working not OK any longer. Aside for what can be seen in the video it also goes black for brief periods.
And this is not my TV :S
Can you help fixing it ? What gives ?
http://194.150.85.156:8080/html/VID_20160221_144602.mp4
Alec_t
Jul 7, 2015
3,820
Presumably the rocking resulted in excess pressure on some component and broke it or dislodged it or cracked a circuit board trace? I'd recommend a VERY careful inspection of the whole set with a powerful magnifier.
kellogs
Jan 7, 2014
94
Ah, false alarm, sorry. It was just a loose HDMI connection due to the HDMI extension cord. Thank you both.
kellogs
Jan 7, 2014
94
Or.. not so fake. Of the two HDMI ports one behaves as described. The other one presents similar symptoms but on a much lower scale - almost none. I am guessing I should look at the HDMI connectors.
AmidBahar
Mar 6, 2016
9
Hello
Please let me what was the problem initially and what you repair it. So that we can assist you in a better way.
kellogs
Jan 7, 2014
94
Well, visual inspection revealed nothing wrong, and the problem only manifests itself if that HDMI extension cord is used. I don't think I should bother anymore about it. thanks anyway.
