TV tx
MNA
Apr 9, 2006
204
1. What specifications are req. for good Video(Audio also) transmitters? ....
2. Can we use fm transmission for remote controlling switches(just ON and OFF)? How?
audioguru2
Apr 6, 2004
12,026
low distortion, low noise, wide bandwidth.
Yes. Use an FM transmitter and an FM receiver. The receiver can simply detect any modulation or can detect a certain tone frequency that has modulated the FM carrier frequency.
MNA
Apr 9, 2006
204
Audio, Can u tell  me about (Video tx)it's complete block diagram.....or Is it just similar to voice tx.
audioguru2
Apr 6, 2004
12,026
A video transmitter block diagram is shown in Google, in Howstuffworks and in many other websites.
For TV, a video transmitter is an AM transmitter with a mixer to mix the sync pulses with the wideband analog video. Colour TV is a little more complicated since there are a few completely different ways that are used around the world.
MNA
Apr 9, 2006
204
Receiver?? how?? how can i use it to operate as a switch(for eg. to switch on a transmitter(video tx for suppose) placed somewhere at a distance where my transmitting pulses(for switching purpose)  can reach  that can switch the second transmitter(video tx or ....) )
audioguru2
Apr 6, 2004
12,026
Maybe you are not allowed to transmit RF without a permit in your country.
Maybe you are allowed to use a 433MHz certified transmitter module that has a short range and can be used by anybody who could also accidently activate your receiver unless you use a secure code.
MNA
Apr 9, 2006
204
Range is not a big issue....it can be small to remain in the limits...... but what i want is to operate my tx (for suppose if I make a video tx..and it is put somewhere not far from my house or can be in my house...if range is realy serious!! I will want to switch on that tx by sitting in front of my tv....just what I am trying to do is to combine  a remote switch and  a video or audio tx......Can u guide me on this....
MNA
Apr 9, 2006
204
Plz., If anyone can tell me more about these circuits, I will be thankful to him....
particularly about "Silent Carrier To A "Beep" Converter"....
http://www.narcbug.com/tt5.htm
http://www.narcbug.com/ddcc.htm
audioguru2
Apr 6, 2004
12,026
The transmitter FM modulates a silent carrier since without the carrier there is a lot of noise and when receiving the unmodulated carrier there is silence.
The audio circuit works and activates the beeper when there is or is not any noise. The radio receiver circuit isn't shown so we don't know all the details.
SM2GXN
Feb 18, 2006
161
Audioguru what do you think?
As I see it the transmitter has several faults, Q1 wrong way should work as a switch and key the transmitter, Q2 should be a NPN and for the final amplifier why it shouldn't work in class C  ::)
audioguru2
Apr 6, 2004
12,026
MNA
Apr 9, 2006
204
I searched for video tx and found many.... But I'm unable to decide which one is better and why.... I've attached one of them....... I really don't know how to judge... Perhaps, you can help me.... Please give me some tips .......
How can I combine my audio and video outputs from VCR to connect to this crkt(my guess ...from poptronix???)
Is this crkt not better than poptronix?.....this crkt uses crystal accuracy ...Isn't it?
audioguru2
Apr 6, 2004
12,026
This circuit can't be received by a normal TV. It is for the amateur radio microwave band.
It dosn't have an input for sound.
Its video seems to be FM modulated instead of AM modulated like broadcast TV.
Good luck trying to find its weird ICs.
SM2GXN
Feb 18, 2006
161
Hi MNA!
These schematics you uploaded are not the easiest to build I would say, to build them you need some "extra" skills in RF technique.
Since the range is not an big issue why not use a RF-modulator from a scrap video then you have both audio and video transmitter or build your own:
http://www.web-ee.com/Schematics/RF_Modulator/rf_modulator.htm
MNA
Apr 9, 2006
204
Skills!!!! I'm a beginner....
I don't know the theory behind these much....
I'm unable to understand that RF Modulator....If u could tell me furthur, it will help me a lot.....
What about the poptronix crkt? .....
Thanx
SM2GXN
Feb 18, 2006
161
Well. the poptronix circuit... just forget it.
You can find an RF-modulator in almost every video player, it's a small box with 4-6 pins, there is inputs for both composite video and audio and a pin for supply voltage.
If you look at the rear of a video you'll see it, it's where the antenna connector is.
MNA
Apr 9, 2006
204
Sorry Sir,but I'm still unable  to understand what u r saying....
what's the connection of an RF modulator with video tx.... ???
How could i send my video output from my VCR to my TV without any connection b/w the two????????
