As I told you if range is not an big issue ;D
Just connect a short piece of wire to the center pin of the output connector of the RF-modulator and a short piece of wire into the antenna connector of the Tv-set, if the distance between your tv and video player isn't to far you will se the video sent by the video player on the tv screen. You'll have to put your tv on same channel as the RF-Modulator otherwise you wont see anything.
Forgot to mention, the two wires act as antennas.
