Tweaking spice models to generate device parameter variation
Paul Burridge
I need to check the efficacy of a new FET biasing scheme to see how
tolerant it is to the wide parameter variations one gets with
real-world FETs. Hence, the usual spice model for a FET with its
invariable Vgs(off) and Idss isn't going to be of any use. If I change
the parameter "Vto" (which I believe is the same as Vgs(off) in the
real world from between say -2 to-6 volts, will that alone suffice to
emulate real world manufacturing variations? I mean, will tweaking Vto
alone also change the Idss to the appropriately meaningful value for a
FET's characteristic quadratic transconductance curve?
THanks,
p.
K
Kevin Aylward
Paul said:
No. You need to change Beta (or Kp), the transconductance as well. SS
already has built guestimates if you use its WC run facility, so you
don't have to ask these questions, usually...
For frequency response you would also have to change the capacitance
parameters, again, WC are already defaulted in SS:)
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
Paul Burridge
Thanks, Kev. These runs are only at a fixed LF, BTW.
Paul Burridge
I've just had a look, Kev. Would I be right in thinking one selects
the component/properties and then chooses between "weak, nominal or
strong" to get the MC parameter variations for a FET? That's what
seems to be happening, as I note the values change according to which
of the three selections I make? Does this accurately represent the
manufacturing spread one would expect to see in real-world devices? It
would save me having to cobble up my own probably inaccurate
guesstimates, you see.
K
Kevin Aylward
Yes. To do a forced run. In most cases, you just run with the nominal,
and use the Worst Case or MC runs to do the actual variations
automatically (blur "SS" button, WC reruns tab)
It will look for a specific model variations in the library
(basename_XN, basename_XW, basename_XS). If it cant find one, it will
use default multipliers that are set in \defaults\SuperSpice.lib to
create one. Once it creates one it will use that one always afterwards.
If you reset the default multipliers you will need to manually change
the auto created one, or delete it so that it will be re-created.
That's what
Well, "accurately" is open to debate. I just checked what I had
SuperSpice.lib, and for the jfets the default variation for Vto is
probably a bit low. Its set to 1.25 and 0.75 scale factors. A better
guesstimate is probably about 2 and 1/2. I must have rushed this a bit.
If you press the help on the WC setup page, you wil get a description of
what happens.
It
I'll go back over my defaults to make sure that they are all reasonable.
Kevin Aylward
[email protected]
K
Kevin Aylward
Kevin said:
reasonable.
Well, I must admit I am rather embarrassed by this. There was another
discrepancy. The Vt multipliers were the wrong way for jfets. That is, a
strong model should have a low vt, weak a high vt. Not sure how this
crept in but I did have:
*these demo models may not be accurate
*worst case models only illustrate functionality
In the WC setup file (SuperSpice.lib, so I did had a cop out:)
I have now updated the download with a corrected version that has better
defaults for the jfets.
Kevin Aylward
[email protected]
Paul Burridge
Thanks, Kev. I'm grateful to you for looking into this for me before I
carried out any runs. It's reassuring to see that you've been open
about this problem and dealt with it swiftly instead of sweeping it
under the carpet as others might have been tempted to do. Respect is
due!
Many thanks indeed. I'll give it a whirl this afternoon. I had noticed
the spreads of your hi-med-low parameters were quite close together -
pity the manufacturers can't make the real thing to your tolerances!
