audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
Man! That translation gave me a hard time. The project is here:
http://electronics-lab.com/projects/audio/002/index.html
If wired as shown, then this project produces a notch filter at the crossover frequency. Due to phase shifts of 2nd order filters that are used, sounds at or near the frequency of the 3500Hz crossover from the woofer and tweeter cancel at your ears, if you are on axis and fairly close to the loudspeaker. The sound quality is not good.
If the polarity of one speaker is reversed then the sound quality is much better, except then the frequencies at or near the crossover frequency are a little too loud.
Many audio experts agree with this theory and one expert's explanation is here:
http://www.trueaudio.com/st_mr2.htm
To completely avoid these problems I always build two-way crossovers using 3rd order filters. The additional cost is only 1 capacitor since I use the woofer's voice-coil inductance instead of an additional inductor, and use a standard 3rd order filter calculation for the parts.
