UK plug/psu - faint whining noise until connected to device?
151
hi all,
I just bought a new gadget (a cheap IP camera) the plug/psu of which
makes a faint high pitched whining noise when connected to the wall
socket - UNTIL I connect the other end to the camera (camera works
fine by the way). Then the noise stops.
When I plugged it in at the socket, the wall the socket was already
switched "on" and there was a little bit of a spark I think... I have
seen this occasionally before (I have no idea if the psu was totally
silent before this or if its a factor)
Also I noted that the "top" prong of the plug (UK plug) was plastic?
I.e. no earth. Could this cause the small spark I saw?
What might this noise be and should I worry?
thanks guys!
Arfa Daily
Doug Smith W9WI said:
Is this PSU relatively light in weight? (I'll bet it is)
I'm betting this is a "switchmode" PSU. There's a high-frequency
oscillator in there which, you could say, steps up the 50Hz mains
frequency to several thousand (/tens of thousands) Hz. This allows the
use of a smaller & lighter transformer to step the voltage down from 240V
to whatever the camera wants.
The actual frequency the mains are stepped up to is not well regulated.
(and doesn't need to be) I would not be surprised if it changes radically
with load - if it's much lower when the camera isn't connected and drawing
power. With no load it might be dropping to a frequency low enough to
hear, while with the camera connected it may be above the range of your
hearing.
Or, it may be reaching the mechanical resonant frequency of some part of
the PSU, allowing that part to amplify the vibrations, and the sound.
Should you worry? Good question. I think the noise would probably bother
me to the point where I wouldn't operate it with the camera disconnected
for that reason alone.
I know little or nothing about the way the UK power mains are wired so
can't really comment on the lack of an earth. Here in the States, these
plug/PSUs almost never have an earth pin at all, plastic or metal. It
would seem unnecessary if any part you can touch is isolated from the
mains by the transformer.
One of the reasons that the plastic earth pin is included, is that the line
and neutral connectors in the wall socket are always shuttered. Sometimes,
the shutter has shaped faces a bit like those on a security screw, such that
when the plug pins are inserted, the shutter 'twists' out of the way,
allowing the pins to pass by it. Many other sockets, however, have the
shutter mechanically linked to the earth pin hole, so that as the (longer)
earth pin goes into the hole, the shutter is pushed out of the way for the
other two pins to follow into their holes. Hence the dummy plastic 'earth'
pin is needed to work the mechanics, where no 'real' earth connection is
needed.
Arfa
151
hearing.
Yeah it is indeed a switching PSU - at least it works at 100 - 240
volts...
The noise is not noticable unless I am pretty close, and then only
when the cable is dangling loose and not connected so its not really
an annoyance - it just made me a bit nervous :)
I can live with noise but I dont like fire!
Eeyore
151 said:
hi all,
Obviously the no load on the PSU causes it to whistle. A side effect of
some switchmode designs.
Maybe 'inrush current'. Not unknown.
I have
No. It just means the PSU is 'double insulated' and needs no earth.
Without the plastic earth pin the socket won't open.
No.
Graham
Eeyore
Doug said:
I would be EXTREMELY surprised if running it without a load would result
in fire. (but there's always Murphy's Law!) Actually, I'd be pretty
surprised if it would result in failure of the PSU as well, but over time
it could happen.
CE safety regs should test for that.
Graham
Mike Tomlinson
UK power sockets are shuttered and a mechanical device physically
prevents you from plugging anything in unless an earth pin is present,
so even if an earth is not needed for the device, a pin is still
required. Obviously, it's cheaper to make it in plastic.
151
Thanks very much all for your help, really good info - so far the
thing seems fine so I feel more confident about leaving it switched
on :)
cheers!
