Ultrathin Flexible Rechargeable LiPo Batteries
João Ambrósio
Oct 29, 2015
3
Hi!
I need a ultrathin (more or less maximum of 1mm thick) flexible rechargeable lithium polymer battery with specific dimensions. As it will be used to validate my project i just need a few samples. I asked some re-sellers but as it has to be custom made the prices are a little bit high. Do you know some manufacturers that can make these kind of batteries?
Thanks in advance!
Cheers!
14,484
and what are the other 2 dimensions ? length and width ??
bigone5500
Apr 9, 2014
712
He might be asking for manufacturers that produce custom cells.
I know of none.
14,484
I know of none.
me neither .... would be very specialised
@João Ambrósio I really expect you would need to go to various LiPO manufacturers directly and see who
could supply that for you and for how much
If you could convince them that you would be placing large orders after the design was validated, you might be able to get someone to produce samples for you. Otherwise, I expect the cost would be prohibitive.
bigone5500
Apr 9, 2014
712
The length is about 50mm and the width is 25mm.
yes, he said in his first post ... 1mm or less
definitely would be a specialised production
HAHA! I was just testing to see if you read the first post...yeah, that's what it was.
Aside from that, wouldn't a LiPo that thin be very limited to the current produced? It would seem to me that it could overheat more easily.
shumifan50
Jan 16, 2014
579
It seems that a crucial part of battery spec has not been mentioned: What should the maH and voltage(might need multi cell) rating be. Depending on requirement, it might very well be impossible to achieve with those dimensions.
João Ambrósio
Oct 29, 2015
3
I need at least 20mAh, the tension will be between 3,3V and 4,3V and the maximum current will be 30mA.
Thanks a lot for the previous answers!
