Universal battery charger
walid1
Jun 27, 2004
749
In the circuit shown below there is a Universal battery charger from:
http://hem.spray.se/lythall/power/charger.htm
it is easy to understand and to implement, but i have some questions:
(1) Why u think the designer use the 4u7 cap.
(2) If LM358 is used as a comparator, why:
      (a) using 820K resistor
      (b) not using 741 single op-amp instead of this dual op-amps
(3) If I want to use this charger to charge a 9-volt square batt, how can i tune this circuit to fully charge my batt
(4) If I want to use a NPN trans type instead of BC557,what the modifications that must be done?
(5) If I want to charge atwo 1.5V batts in series (3V) using a 5V power supply, what to do other than changing zener to 3.3V?
thats all,
thanks. View attachment 37979
audioguru2
Apr 6, 2004
12,022
The actual value doesn't matter. It filters noise from the battery if it is loose in the connector and provides a small delay.
walid1
Jun 27, 2004
749
audioguru: "The actual value doesn't matter. It filters noise from the battery if it is loose in the connector and provides a small delay."
Walid: it is good news that the cap value (4.7u) doesn't matter, but still i can't understand u, please explain it more for me, thanks.
walid1
Jun 27, 2004
749
audioguru: "Without it then when the battery voltage reaches the threshold voltage, the circuit might oscillate."
Walid: (1) What the threshold voltage if the charged batt is, say, 9v
          (2) is this op-amp oprate as a comparator. I never see a comparator with a feedback resistor.
audioguru2
Apr 6, 2004
12,022
The threshold voltage is adjusted with the pot.
The opamp is definately used as a comparator. The 820k resistor provides a little positive feedback for snap-action switching which avoids oscillation at the threshold. The slow opamp that is used as a comparator probably won't oscillate but at the threshold it will amplify its noise and cause output fluctuations without hysteresis provided by a little positive feedback.
Comparator circuits commonly use positive feedback for hysteresis.View attachment 38004
