unknown electronic component.
hernault
Nov 8, 2016
3
Hello.
I'm a french guy and i try to repair an american machine. I have the electrical shematic but there are some component i can't identify. In France we doesn't use the same schematics.
I give 2 pictures.
Sorry about my bad writing.
Thank you for your help.
Best regards.
Minder
Apr 24, 2015
3,560
1 is a solenoid coil.
2 is a Proximity switch
3 appears to be a centre off Limit Sw that is operated from two directions. Although that is a new one on me.
But a normal L.S. does this.
M.
hernault
Nov 8, 2016
3
Thank you Minder for your answer.
If the 1 is a solenoid coil a give you a picture that shows 2 kinds of solenoid coil. Could you tell me the difference betwen them?
Best regards.
Minder
Apr 24, 2015
3,560
Usually 1 would be a contactor or relay coil and 2 would be a solenoid.
These are the common differentials, there is always a possibility the OEM may have drawn with a slightly different meaning, but looking at that, that would be my interpretation.
The wire A1 & A2 label also confirms the common notation for a coil
M.
