H
Henry Kolesnik
- Jan 1, 1970
- 0
What the easiest ways to measure the output impedance of a push pull
tube amplifier?
Hank
tube amplifier?
Hank
tube amplifier?
Hank
tube amplifier?
Hank
Henry Kolesnik said:This is in an old military radio which I suspect is not 3.2 ohms but
somewhat higher like maybe 600. It's kind of hard to get to the
primary. I guess I should have stated that at the beginning. I kind of
recall some way of measuring the open circuit voltage from a tone and
then with a pot connected across the output, set the pot to where the
voltage is 1/2 and then measure the pot. Do I have that correct?
Hank
Henry Kolesnik said:What the easiest ways to measure the output impedance of a push pull tube
amplifier?
Just in case the amplifier is 'unhappy' with such a low load, it mightCharles said:Load the amplifier with an adjustable resistor. When the loaded output
voltage drops to 1/2 of the no-load voltage, the resistor can be removed and
measured with an ohmmeter.
Sorry, not so. This will only give you what I originally mentioned,
i.e. equivalent generator source impedance (see Thevenin),
and it will
be very low - no use in selecting speakers.
You need the O/P
transformer (OPT) ratio. Make sure the receiver/amplifier is OFF. Use
a filament transformer run off a variac to energise the OPT secondary
(use the speaker terminals) - keep it low, say 2 to 4 VAC. Measure
the OPT primary and secondary voltages at a few levels. Calculate
each ratio and average them. Figure out the correct plate load for
the O/P tube (not covered here) - it will likely be in the range 4
Kohms to 8 Kohms, call it Rp. Then the correct speaker load will be
Rp/OPT ratio squared. Ex: Rp = 5000 ohms, OPT ratio found to be
36:1. Then, speaker should be 5000/(36)^2 = 5000/1296 = 3.86 ohms.
So use a 4 ohm speaker.
Cheers,
Roger
removed and
In message
(snip)
But what does the invariable negative feedback (from the OPT secondary
to an earlier amplifier stage) do to the output impedance?
Ian, it reduces the source output impedance of the amplifier as a
voltage generator (increasing the damping factor) but does not affect
the speaker impedance to be used. The speaker impedance determines
the O/P tube plate (anode) load via the OPT ratio.
Cheers,
Roger
In message
But the original question was "What the easiest ways to measure the
output impedance of a push pull tube amplifier?" It didn't mention
loudspeakers.
Henry mentioned a miltary radio with a high output impedance (but I
don't know any with P-P output...) I have a BC348 and the OPT (from a
single 6K6 O/P tube) is designed for 'phones only, both "high" and
"low" impedance. The "low" impedance 'phone O/P is 300 ohms so using
a regular LS is not possible. I put a typical radio OPT in this radio
(I left the original 'phones OPT in place so it could be restored to
original sometime in the next 100 years!) The new OPT and the nominal
8 ohms LS used puts a reasonably correct plate load on the 6K6, about
7K. Volume is quite good - I'd guess about 2 watts output (but not
measured.)
There is no NFB in the original radio but there is a little bit now as
I routed the Rk decoupling cap to the top of the OPT secondary as a
token NFB (properly phased.) Of course, invariably there is a lot of
NFB on P-P audio amplifiers and, as noted above, it reduces the true
output impedance of the amplifier as a voltage source, but it does NOT
change the correct LS impedance as the latter defines the O/P tubes'
plate-to-plate load.
I don't know why Henry first asked about a "PP amplifier then "morphed
to a "military radio" but it doesn't matter - it's all the same
physics!
Cheers,
Roger
Dave Plowman (News) said:Usual reason would be to drive several small speakers or to do so over
a
long run - like 100v line. Where a matching transformer is situated
with
the speaker.
*I believe five out of four people have trouble with fractions. *
Dave Plowman [email protected] London SW
To e-mail, change noise into sound.
