Use USB memory stick as random memory?
Bill Bowden
Is it possible to use a little USB flash drive as RAM memory for a PIC
microcontroller project without a lot of serial I/O software?
How complicated is it?
What procedure is needed to read and write a single byte to some
location inside the USB flash drive?
I'm guessing it requires writing and reading entire files to move
small bits of data.
-Bill
N
Nicholas Sherlock
small bits of data.
The drive doesn't know anything about files. You read and write blocks
of data to locations on the flash. You have to implement USB host and
issue USB commands over the wire, which is pretty painful. Why do you
want to use a USB flash drive? You might be better off with, say, an SD
card, which has a far simpler interface designed for small devices to
implement.
Cheers,
Nicholas Sherlock
Rich Webb
Nope.
Fairly. You'd need to implement a "USB host" to talk to the USB flash
drive. Depending on which side of the build/buy equation you're on, you
can get pre-packaged interface libraries.
small bits of data.
If you have to have a USB drive (customer requirement, etc.) then you
do. But, if you just want a ton of flash storage, then it's probably
easier to implement an SPI driver for SD cards in MMC mode.
Here's a link to a PIC project that does just that
http://www.captain.at/electronics/pic-mmc/
Bob Monsen
small bits of data.
-Bill
If you want to use SD, you might use this:
http://www.futurlec.com/Mini_SC.shtml
It is a 'miniboard' from those Australian guys. You can use it to read and
write an SD card. It is basically just a breakout board, but you won't have
to run your own board.
Regards,
Bob Monsen
Don McKenzie
small bits of data.
1)
http://www.dontronics-shop.com/4d-udrive-usd-g1-tiny-disk-drive-data-storage-module.html
2)
http://www.dontronics-shop.com/ftdi-vdrive2.html
Cheers Don...
Don McKenzie
Site Map: http://www.dontronics.com/sitemap
E-Mail Contact Page: http://www.dontronics.com/email
Xbee Wireless Modules, and low cost Interface Boards.
http://www.dontronics-shop.com/xbee-boards.html
