using an electromagnet to OPEN a small door
Sammy Taylor
I'm building a small safe with an electronic strike. When a timer activates,
the strike releases. I want the door to pop open, and using a spring is
awkward. I thought a simple electromagnet might work, (activated just AFTER
the strike releases to prevent pre-load problems.) Can somebody suggest a
geometry.
Cheap strong electromagnets seem to be of the U-shaped variety. Can I use
one
of these and a permanent magnet to repel each other? (I can't use two
permanent magnets because the pre-load on the strike can be enough to
prevent it from opening.)
Thanks for any help.
sammy
cbm5
Sammy said:
geometry.
one
sammy
Something wrong with just a normal solenoid?
Robbie Mayhem
Sammy Taylor said:
activates,
AFTER the strike releases to prevent pre-load problems.) Can somebody
suggest a geometry.
one
sammy
Most security equipment suppliers will sell this type of equipment (access
control), at least they do in the UK. Suggest you Google and try and find a
local supplier.
Rob
