Using electric field to thin fuel
George W Frost
Mr.T
TT said:
It has been done before and will be done again.
As long as there are gullible people with money anyway. You can more easily
"thin the fuel" by simply routing the fuel line closer to the exhaust
manifold anyway (not that it will improve economy though, unless possibly
the car was running too rich to start with, only if modern electronic fuel
injection and EG sensors are not in use)
However the fire risk may increase though :)
Here is a basic test to apply to any device like this that you see
advertised. "If a simple device like this could deliver even a 5% increase
in fuel economy don't you think GM, Ford, Toyota etc would snap it up and
put it on their vehicles?"
Hell a 1% *genuine* increase in fuel economy would be enough. But they have
proper test benches to accurately measure fuel consumption at all load
levels, something the snake oilers never bother with.
Or wouldn't you at least to expect to see it in F1 racing?
Peter Brock used it on his car didn't he :) :)
MrT.
F
Franc Zabkar
The following article refers to two sets of tests, one by the
researchers, the other by an Italian diesel engine manufacturer:
"Electrorheology Leads to Efficient Combustion"
R. Tao,* K. Huang, H. Tang, and D. Bell
Department of Physics, Temple University, Philadelphia, Pennsylvania
19122
http://pubs.acs.org/cgi-bin/sample.cgi/enfuem/asap/html/ef8004898.html
This is a more technical article on rheology by the same researchers.
It is aimed at reducing the viscosity of crude oil for transportation
via pipelines:
"Reducing the Viscosity of Crude Oil by Pulsed Electric or Magnetic
Field"
http://pubs.acs.org/cgi-bin/sample.cgi/enfuem/2006/20/i05/html/ef060072x.html
This is a Wikipedia article on the subject:
http://en.wikipedia.org/wiki/Electrorheological_fluid
I notice that Tao's group has used a diesel Mercedes-Benz as their
test subject. Why not a petrol engined Chevrolet sedan? It seems to me
that the planet-saving potential of his magic device would be
maximised in the consumer car market.
The news article states that ...
"Temple [University] has applied for a patent on this technology,
which has been licensed to California-based Save The World Air Inc.,
an environmentally conscientious enterprise focused on the design,
development, and commercialization of revolutionary technologies
targeted at reducing emissions from internal combustion engines."
- Franc Zabkar
F
Franc Zabkar
It has been done before and will be done again. It is all bullshit.
That was my first impression, and I'm still very skeptical, but the
researchers appear to have some independent test results that support
their claims, at least in respect of diesel engines.
The researchers claim that one Italian diesel engine manufacturer has
tested the device and obtained a 5% improvement on the dyno.
These guys spend Billions on more fuel
efficient vehicles and you really think some nut case in a back room can do
a better job?
The researchers are physicists based at a university.
It couldn't even be tested without serious modification. The
researchers found that at 1900 RPM the optimum electric field was
1kV/mm, and the minimum time required for the fluid to be subjected to
the field was 5 seconds. The fuel flow under racing conditions would
be an order of magnitude greater, which would mean that the device
would need to be much longer. Of course you could have one small
device per cylinder ...
Cheers TT
- Franc Zabkar
terryc
Yep, I've got an engineer mate who served as a ships engineer and he tells
the story of getting some thin (compared to the tar they had) russian
diesel fuel for the ship and "the old girl practically flew all the way
home"
All the scamsters say that same sort of stuff.
Did they list the reference and did it check out?
Or is this "trust me, would I lie to you" all over again?
Mr.T
via pipelines:
Field"
ml
Which is obviously a more appropriate use, since there is no evidence
tendered that reducing the viscosity of the fuel actually leads to increased
efficiency when used in a properly tuned car engine in the first place.
MrT.
Mr.T
Actually they say the effect lasts for a couple of hours, so could obviously
be done in the fueling rig before it even goes into the racing car. Therfore
no weight penalty, or other problems.
MrT.
Mr.T
the_dawggie said:
Well 'lux turbo diesel made it to North Pole.
I'll bet they used a fuel additive though!
(Commonly added to diesel in all extremely cold climates.)
MrT.
Bernd Felsche
That'd be called "petrol".
Eeyore
TT said:
Applying for a patent does not necessarily mean the thing works.
Nor does having one granted ,esp by the USPTO who are only interested in your
money.
I fully expect MOST patents in the USA are TOTALLY worthless.
Graham
Bob Parker
BTW Harley's are the most efficient engines at turning petrol into noise
without the side effect of horsepower ;-)
Ah-hah ... That's what I always suspected!!
K
Kev
MrT.
K
Kev
the_dawggie wrote:
Trevor Wilsonwww.rageaudio.com.au
Make sure you get it right
MODIFIED turbo diesel Hilux with Arctic compatible fuel
Kev
