Variable DC
colum
Jul 25, 2013
180
I want to drive a small DC motor with a 12 volt battery
I need to vary the voltage to the motor from about 6v to 9v to speed control
If possible I would like a simple circuit.
An ordinary wall plug in transformer works well but is not variable.
Thanks for all advice
Jeff
kellys_eye
Jun 25, 2010
6,512
Motor speed control is usually achieved using a PWM (pulse width modulation) system - varying the DC will work but won't help when the motor is under load. Small motor control modules are readily available and very cheap.
Typical (but not only) example and that price is for THREE!
colum
Jul 25, 2013
180
Thanks kellys eye
They do not mail to the US.
I will try for a 3055 and some variable resistors
Standby for the smoke
Kiwi
Jan 28, 2013
506
Amazon and Ebay have lots of these PWM speed controllers.
Probably $2.00 on one of the online suppliers.
Can't buy the bits for that.
colum
Jul 25, 2013
180
Thanks Minder for your circuit
I built a PWM circuit with 2 555s and a transistor and the results looked great on my meter
that went down to 6v but when I hooked it up it the speed did not seem to vary
I'm sure it was my error.
so I will try for a regular voltage reducer with a 3055 etc
Jeff
crutschow
May 7, 2021
991
Depending upon the motor current the 3055 will require a heat-sink.
That's the advantage of using PWM, as the transistor requires little or no heat-sink.
14,487
Thanks kellys eye
just do a search for the same product on your USA ebay
Small DC Motor 5A PWM Controller Speed Control Driver Board
tisnt difficult
it's the ONLY way you will be able to reliably control the motor
As others have said, your variable voltage scheme wont work properly
as the voltage needs to be kept stable
