define a variable in header file
14,317
Please try to find out by yourself. You'll learn much more by this.
To do so, simply follow the instructions manually - easy as there aren't many:
Check the variables i, start, last, temp and array[] at each step - simply write the contents on a piece of paper to trace the program flow.
For i=0, 1 and 2 the program obviously delievers the correct output.
Watch especially what happens when i reaches the values i=2, i=3.
The case i=4 is then trivial.
This should make it obvious to you where the error is.
