Variable duty cycle and frequency with a 555
captoro
What is the definition of "fast rise and fall time"? How fast?
...Jim Thompson
| James E.Thompson | mens |
| Analog Innovations | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona 85048 Skype: Contacts Only | |
| Voice:(480)460-2350 Fax: Available upon request | Brass Rat |
| E-mail Icon at http://www.analog-innovations.com | 1962 |
I love to cook with wine. Sometimes I even put it in the food.
How fast rise time ?? .. Fast , I am experimenting now, the fastest as possible !.
I have been working on a circuit with a PIc chip like I said earlier works good, well kinda.
OH. before I forget I did install some 5 and 10 turn POT, some old shop near my house had a drawer full, I took 6 for 20$ .
The circuit seems to work at 12v input through the coil, But if I put 24v (I have not tried 36v yet as seen on the schematic) the coil get pulsed on and off in a random fashion !!
I'LL hook up the scope on the PIC see what happens
And yes all the grounds are connected together and then connected to a metal rod in a proper grounding fashion.
K
captoro
The circuit seems to work at 12v input through the coil, But if I put 24v(I have not tried 36v yet as seen on the schematic) the coil get pulsed onand off in a random fashion !!
K
here is the link:
http://www3.sympatico.ca/captoro/
Jamie
captoro said:
Trying to figure out what you're attempting to make has become
challenging. In the above link it states you have 6 MFETS in series?
I can only imagine you mean they are in series on a heat sink but
electrically together in parallel?
Next, you don't state if the 10uh coil is a high Q type and maybe
a rather large one?
You do realize that with fast edges you'll end up with lots of voltage
at the drain? Of course you could load the DRAIN down with caps and
make an induction heater coil using the ringing to generate the 50khz
average that is generally used.
Just a thought.
Jamie
captoro
a rather large one?
Just a thought.
Jamie
Hi, there are 8 Mosfet in parallel in tow rows. they are rated 400v .
the problem I am getting is when I supply current to the coil, (which is probably not 10uH because I used the default one in Orcad, I'll need to calculate if you want. It has 300 feet wire wrapped on a 2 inch diameter PVC and3 inch long) . the problem is when I put on the 36v actually 24 v, the output pin from the picchip stops randomly for oscillating ....
I mean 1 second on 0.5 second off etc...
K
mike
the problem I am getting is when I supply current to the coil, (which is probably not 10uH because I used the default one in Orcad, I'll need to calculate if you want. It has 300 feet wire wrapped on a 2 inch diameter PVC and 3 inch long) . the problem is when I put on the 36v actually 24 v, the output pin from the picchip stops randomly for oscillating ....
K
A quick sanity check registers in the insane region.
If you put 36V into 10uH, the back of my envelope says the current ramp
is 3.6 MILLION AMPS/SECOND.
Round numbers...1 kHz. 99% on time is still 3.6 thousand amps.
And that's only the first pulse.
I think you're gonna need bigger wire.
Unless you're located at the power substation, it's not surprising that
something is shutting down.
The thing seems fraught with issues.
What are you trying to accomplish?
captoro
I modified the circuit value, because i said earlier that the coil value was not good, Now after measuring it I posted up the corrected circuit.
what I am trying to accomplish??
I am trying to replicate a motor winding
But pulsed instead of using steady DC.
But my pic randomly stops working, I would understand if the fuse blows, heating wire ... but why would it stop, I am thinking it comes from the ground, sharing the same ground as the coil. ?!?
K
K
mike
might be resetting the pic. Put a led+resistor on one of the outputs
and flash it during
initialization of the pic.
That will tell you if it's resetting.
I just looked at the pictures.
I don't think you have a prayer of making that work.
You've got wires running all over the place and huge magnetic fields
being generated.
Get the PIC and the pots and display in a shielded box away from the
FETs with lots of power supply decoupling.
The shielding may not help much with magnetic coupling, but making
the wiring shorter will help.
You may be able to get the FET ground currents contained by careful
management of what is wired to what and parallel conductors for + and -
to minimize the magnetic field. If not, you can try transformer or IR
coupling from the pic to the driver.
You can't just turn off the FETs with current in the inductor.
The energy has to go somewhere. It's best to control where it goes.
Google "Miller Capacitance" and see if you have enough drive
to charge the EFFECTIVE input capacitance. That also explains
why the FETS are so slow turn off...and will get hot.
Are we having fun yet?
captoro
and flash it during
being generated.
I thought of using optos too, i just didnt have here that are fast enough.
I think that might be the problem, The wires are the shortest I can put them , Except for a load parallel to the coil with two diodes.
k
mike
That's nonsense.
Get the PIC out of the middle of all that high-current high-voltage stuff.
You've got pot wires curling around the fets.
No sight of any power supply bypassing. OR decoupling.
You can't just "wish" that it works. You gotta design it
so it works and rearrange the wiring so it can work.
There's some art to this kind of circuit. The reason your pic
might be resetting is not on the schematic you posted.
Redraw the schematic with the grounds connected exactly the way
they are in the wiring. Insert inductance and resistance in every
ground lead. Then add some mutual coupling between those inductors.
It's not magic, but it is tedious.
Get rational about the voltages/currents/risetimes you need.
Fast as possible, is not a spec. Any mention of 10ps risetime
for this circuit is ludicrous. Put numbers on what you need
and design for that.
captoro
That's nonsense.
Should I make a board for the PIc & mosfet driver and a separate board the mosfet and coil??
k
mike
Should I make a board for the PIc& mosfet driver and a separate board the mosfet and coil??
k
You could make an argument for either. The idea is to get the PIC out of
the middle of all that high current stuff and limit the "antennas" for
all the interconnect rat's nest.
The PIC/knobs/display is a useful piece of test equipment. In that
respect, it makes
some sense to package that together.
There's still too much undisclosed to be able to offer much help.
On the path you're on, you're gonna learn how inductors behave.
And you already know that.
And when you finally get it working, you're likely to learn how
to blow up fets 8 at a time...and magnetize everything within reach.
You still seem to be working on the "best as possible" theory.
Figger out what you need before you build it. Numbers are your friend.
If you're gonna drive a motor, hook up the motor and deal with all
the parasitic effects.
captoro
Why don't you back up and describe exactly what it is you're
trying to accomplish. You're making no sense.
...Jim Thompson
Jim,
I am trying to replicate an experience i saw on youtube:
I am using a different oscillator, the rest is the same
K
captoro
So the CFL is wired across the coil?
I take it, from the YouTube comments, that no schematic exists?
Lose the Google, post via a real Usenet provider.
...Jim Thompson
I posted the schematic on my web site. But he uses a 555 timer, and at the output a CFL is to be placed.
K
mike
Jim,
K
Nope, the rest ain't the same.
He separates the functions and manages the ground currents.
The devil is in the details and often not shown on the schematic.
WOW! A video showing that he can flash a light.
Makes no claims.
Draws no conclusions.
I want the 7 minutes of my life back.
captoro
Returning to pulse generation rather than vagaries, the pulse
generator is trivial...
http://www.analog-innovations.com/SED/Freq_Duty_555.pdf
...Jim Thompson
Thanks Jim I will try your circuit.
here is the original post:
You cannot see the CFL, but there is another video which he has 5 CFL fully turned on. Hes got wires going all over the thing. Plus in my circuit pictures, all the black wires are redundant ground on the board,
K
josephkk
Jim,
K
What a horror. I am surprised that the CFL didn't emit smoke. I can only
find a lightning strike a worse torture for the internal driver circuit.
It is definitely worse that IEEE Class C impulse rating.
Use a full transformer with L-R series load, instead of a simple inductor
to model a motor. You will find a real motor jumpy and twitchy at the low
frequency range of your system.
captoro
You think that is crazy, with this simple oscillator , he is able to light 5 CFL on this video:
I can hardly dim one with my circuit !!
Apparently some people has been able to replicate it. so that what I am trying to do
K
captoro
I added an opto coupler to the circuit to isolate the ground from the coil.
Its working 100%
BTW I thought about the EM wave some where mentioning earlier, I am only oscillating at 5Hz, so I dont think that is an issue here
Thank for all the time you gave me
K
josephkk
Its working 100%
K
Just in case you are still reading, the EMI issues come mostly from edge
speeds rather than fundamental frequency.
