The obvious question is why would you bother?
edge speed ??? you mean harmonics ??
The faster waveform rise time means that the higher harmonics of the
fundamental remain significant. In the limit that the waveform becomes a
delta function like spike then all harmonics are present with equal
weight. A real narrow pulse has finite width. I presume this is a device
designed to destroy MOSFETs and CFLs in roughly equal numbers!!!
BTW be careful if you end up flashing bright lights at frequencies in
the 5 to 15 Hz range as if you are even slightly prone to epilepsy at
the wrong frequency you could end up on the floor twitching in a fit.
