N
Nikyu
- Jan 1, 1970
- 0
I have a strobe light which is used to view rotating machinery. It
uses a magnetic tach sensor which has a 0 - 5V output. The output
goes directly into the strobe. I would like to be able to rotate the
image captured by the strobe. Basically, I want to delay the 0 - 5V
signal from the tach by something on the order of 1 ms. The big
problem is the frequency of the rotating equipment is not constant, it
can range from 0 to 2500 rpm. So depending on the angular speed, a 1
ms delay would cause a different angular shift in the image I see.
What I want is about a 15 degree rotation of the captured image and
slow and high speeds.
Any ideas?
Thanks!
Eric
Any ideas?
Thanks!
Eric
