variable phase shift of signals
axr0284
I am looking for possible solutions to be able to phase shift a
signal in the 1 to 4 MHz range by a certain amount between 0 and 180
deg. Originally we were using the AD9501 delay chip but they are going
obsolete. The resolution should be less or equal to 50ps over the
above frequency range.
Some solutions that we have already come up with are
1) using FPGA with DCMs to induce the phase shift. <-- This might not
be realizable at that resolution.
2) Use FPGA to control a DDS and produce the phase shift. <-- Best
solution we have right now but we have never tested it.
3) Substitute the AD9501 with MC10EP195 <-- The ECL voltage levels
might need to be converted to lvcmos/lvttl
I am looking for other possible external solutions. An FPGA would be
controlling the phase shifting. I figured people who work with this
kind of stuff on a daily basis might know. Thanks a lot for any
answer,
Amish
linnix
How about the ELMEC programmable delay?
6 bits from 0 to 750 ps in 50ps steps.
How many steps do you need?
axr0284
John, this is for using a class D power amplifier. I am not too sure
of the details of the amplifier part. All I know is that I need to
produce two square waveforms that have a certain frequency and phase
shifted by a certain amount wrt each other. Most probably an FPGA will
be used to create the square wave and control the phase shift. The
frequency will also be tracked in such as way that a frequency
variation by +-5% should NOT cause the phase shift to change by more
than 50 ps.
So if the signal was running at 4 MHZ, with 45 degree phase shift.
This would mean that signal B would have a delay of 31250 ps wrt
signal A. Now if the frequency changes by +5% for whatever reason.
this gives 4.2MHz. With the same 45 degree phase shift, it would mean
that signal B would have a delay of 29763 ps wrt signal A. In this
case, the phase would be adjusted so that signal B would have a delay
of approximately 31250 ps wrt signal A. I hope this is clear enough.
I will be designing a board that has all the components on it so I
would need a solution like a chip or a circuit that can be mounted on
a board. The ELMEC programmable delay looked interesting but they do
not have a rohs compliant version which is required by my company.
I really appreciate you guys taking the time to answer me. Thanks,
Amish
John Larkin
answer,
Amish
What's the nature of the signal? Is it just a single digital edge, or
a square wave? What parts need to be delayed? Must it automatically
track changes in frequency, or is a programmable time delay enough?
Would this work?
http://www.highlandtechnology.com/DSS/T560DS.html
I can get you the s.e.d. discount!
John
Tom Bruhns
than 50 ps.
Amish
Seems to me that if you are tasked with generating the signals, and
you don't have to accept some arbitrary external signal, the DDS is
just about an ideal solution. I believe you should be able to find
DDS parts from Analog Devices that will do the job for you with
relatively few external parts. Consider that a DDS works by
incrementing a phase accumulator; a phase offset is just a constant
added to the phase accumulator value. The phase between the
accumulator and the accumulator plus offset is then independent of the
amount you increment the phase accumulator each clock. It will be
important to have the two channels have identical delays; 50psec is
only about 5mm of trace length on an FR4 PC board, I believe. If you
have a lot of FPGA resources left over, you could implement the DDS
sine generation there, and just drive a dual DAC from the FPGA. If
you need a square wave instead of sine, you can low-pass filter the
DAC outputs and drive comparators. -- Of course, it's also possible
to calculate the time delay required for a particular phase difference
for any known frequency, and that can be reduced to a number of clock
periods plus an analog-controlled delay. But the DDS likely makes it
easier to generate frequencies with arbitrarily fine resolution.
Cheers,
Tom
than 50 ps.
The Analog Devices range of Direct Digital Synthesis chips include
some parts that produce two separate outputs at a programmable
frequency and with a programmable phase shift. '
http://www.analog.com/en/subCat/0,2879,770%5F843%5F0%5F%5F0%5F,00.html
The DDS chips are listed in the RF/IF catagory.
The AD9854 and the AD9958 offer dual outputs and the AD9959 offers
four.
The master clocks for the DDS chips now run up to 1GHz (but that is an
expensive part). 500MHz gives 2nsec sample spacing which is a lot more
than your 50psec, but DDS chips adjust the amplitude of the signal
coming out of their 10-bit or better output DACs to get much finer
control of frequency and phase.
50psec phase shifts in a 4MHz waveform coming from a DDS (via a low
pass filter) should be entirely practicable.
The parts can be reprogrammed pretty rapidly - this could well be an
interesting solution.
I've not worked with these DDS chips (or any others)., but Win Hill
had an interesting device on his web-site at one time that did use DDS
chips in this sort of way.
Jamie
axr0284 said:
answer,
Amish
Coax cut to length ?
Paul Mathews
answer,
Amish
Check out Dallas Semi DS1021 series.
Paul Mathews
http://datasheets.maxim-ic.com/en/ds/DS1021-DS1021-50.pdf
The minimum delay step of 250psec is a good bit bigger than the 50psec
the OP asks for, and the maximum delay the OP asks for - 180 degrees
at 4MHz, or 125nsec - is more than 256 times times this minimum delay.
It isn't likely to be an attractive solution. The Dallas parts also
have rather poor jitter specifications
The last time I had to do something like this I planned to use the
predecessor of the MC10EP195 to generate fine increments of delay,
interpolating between 2nsec increments generated by a 500MHz crystal-
controlled clock.
The MC10EP195 offers a larger minimum delay range - 7.85nsec - than
the part I planned to use, so one could use a slower clock - down to
128MHz for a single MC10EP195 - which would make life easier and
cheaper.
The problem is that the delays generated by the MC10EP195 increase
with junction temperature at about 1300ppm/C. In my application I
planned on using frequention autocalibration (which would have taken
about 1msec) to measure the actual delays being generated by the fine
delay generator, and expectd that the digital words generating the
delay would be recalulated after every calibration.
The calibration procedure involved generating an 80MHz pulse-width
modulated waveform whose mark-to-space ratio depended on the
programmable fine delay, running it through a low-pass filter and
digitising the analog output voltage.
This would have allowed me to compare delays being generated by the
analog delay line against the period of the 500MHz crystal controlled
clock with quite good precision
I doubt if exactly this approach would work for the OP. In the
appIication decscribed, you might want to built three swappable delay
modules, and cycle around all three, re-calibrating one against your
crystal-controlled coarse clock while the other two controlled the
inverter drives.
In theory, one could string together 16 MC10EP195 parts and stick them
all in something like a crystal oven, but this would be rather bulky.
Granting the rather wide manufacturing tolerances on the MC10EP195,
you'd have to calibrate each delay module at manufacture, and the data
sheet doesn't say anything about the long term stability of the
delays, which could make built-in autocalibration rather desireable -
though this rather depends on exactly what the OP is actually doing.
F
Fred Bloggs
That is not called a "phase shift," it is called a time delay. Your
understanding of the requirements are leading you down the road to a
complicated system with little chance of success. It would be better if
you drop your microscopic view of things and describe the offset clocks
and the class D amplifier in plain language.
axr0284
Thanks for the response everyone. This is going to be an interesting
project since i am pretty new in the RF field. Fred, I definitely do
not have an expert understanding in the matter of phase and delay
difference. Maybe you can explain it to me in a little more detail.
Luckily for me I believe there is another company project using the
DDS AD9958. The board is supposed to be manufactured in the near
future. If the results from that are conclusive, we will probably go
with that but it is still good to have other options under hand. Keep
the ideas coming. Thanks a lot for the help,
Amish
