Variable phase shifter?
Tom Bruhns
Try this approach-- a high-bit counter circuit to measure period. Pop
the period output of the counter into a simple DAC, and scale it however
you need to. Use this as one input to an analog multiplier, and the other
input would be your phase. Turn that voltage into a delay somehow-- a
simple 555 timer charging via some constant current, for example (I haven't
checked speed specs on a 555). The constant current charging means a ramp
to the control voltage.
No ucontroller, no DDS, one counter, a DAC, a multiplier, and a 555 with a
transistor.
(Need a register between the counter and the DAC...)
Let's see--instead of a counter to get the period and a DAC to turn
that into an analog voltage--why not just a ramp that's reset by the
square wave, and a peak detector to monitor how big the ramp gets?
The peak detector output is proportional to the waveform's period.
It's kind of the analog of a frequency-to-voltage converter, but it's
a period-to-voltage converter. You don't really even need a peak
detector; a simple average (e.g., long time constant RC filter) will
do fine, since the frequency doesn't change in use and I can in this
case depend on the stability of the duty cycle of the input.
But how I turn the 555's output to a delay (on a 120MHz square
wave...), I'm a bit foggy on...
On the other hand, I know how to use a voltage to control a wideband
delay pretty well...so this has some possibilities. Thanks for the
idea!
Cheers,
Tom
Scott Seidman
You were saying you're more interested in the timing than the waveform. If
the 1.2 MHz had, say, a 60% duty cycle, you could just use the 555 to
generate the delay pulse, and a simple NAND with the original waveform
would give you a delayed square wave, but the duty cycle of the second wave
would be variable.
Tom Bruhns
would be variable.
That's OK at 1.2MHz, but what about at 120MHz, 8 nanosecond period??
Then we're back to about the same method I was suggesting earlier,
using fast comparators on a fast ramp; I think it's about the same as
your 555 idea, but with the comparator as a stand-alone part. Does
anyone make an "ECL 555"?? ;-) I do appreciate all the inputs--I'm
coming up with something simpler than I originally would have because
of them.
Cheers,
Tom
JosephKK
of them.
Cheers,
Tom
The more i read about this the more i think that a useful approach is
an FPGA implementing a hybrid delay locked loop and PLL for that
frequency range and that phase range. For the 120 MHz end you would
need really fast IO, but not so many pins.
Tom Bruhns
Yes, that's certainly one reasonable way to go. I don't think any
modern FPGA would have a problem with the speed, though--certainly not
the ones we've been using around here. Actually, once you've invoked
an FPGA, you also have opened the door to running an NCO with fine
phase adjustment inside it...
My thanks to all who have provided inputs.
Cheers,
Tom
