vertical output ic jvc av27850
compo311
Oct 5, 2010
3
i had a problem with my vertical ic according to other blogs..iwas going to re solder some joints but when i took the tv apart i could not find it....part number la 7832..does anyone know where it is located..also a funny thing happened while inside the tv...i cleaned it(really dirty/dusty)and pressed down on some of the connections...when i plugged in the tv it came on and has stayed on without the thin horizontal lie i was getting befrore..is this temporary fix or was the dirt/dust the problem????thanks neal
I can't say you've fixed it, but why not leave it be for a while and see if the fault returns.
It may just have been a poor connection somewhere.
compo311
Oct 5, 2010
3
thanks steve,that's what iam going to do..do you know where in the tv the part la 7832 or the vertical ouput ic is located..i have seen pictures of it but i dont see it anywhere in the back on the boards..thanx again neal
No idea.
But it would vary depending on the make/model of your TV. Best to tell us that as TVs don't all look the same inside :)
compo311
Oct 5, 2010
3
location vertical output ic
it is a jvc av 27850 made in 1997...this is a 27 inch color tv..thanx neal
