VHF AMPLIFIER (PLZ ANSWER)
sssaaa
Feb 3, 2006
74
Do I use the VHF AMPLIFIER of this website for FM 75-108 MHZ.
Staigen1
Oct 26, 2003
695
Hi
I dont know if you are using the VHF Amplifier or anyting at all from
this website, but you asked for an answer. ??? ;D ;D ;D
//Staigen
sssaaa
Feb 3, 2006
74
i mean that this VHF AMPLIFIER will work on 76-108 MHZ frequency?
i m using it for FM radio dxing it will work or not ?
Staigen1
Oct 26, 2003
695
Hi
A link would be nice! ???
So we are discussing the same project!
//Staigen
sssaaa
Feb 3, 2006
74
Hi Staigen
you are not able to answer this question leave it man dont worry :) & give chance to others to give the answers of these simple questions.
Staigen1
Oct 26, 2003
695
Hi
Hehe, so i am not able to answer this question, hehehehe
But, there are 3 projects dealing with amplifying signals in the 86-108Mhz range at the RF
Cirquits Projects side. One of them try to amplify these signals, using miller integrators, and
i dont think that is a good design.
leave it man
Ok, i leave it, but it is not a promise
dont worry
Im not worried
I belive everyone is allowed to post in every topic, and usally also are wlecome
Simple? We dont even know wich of the amplifiers we shall discuss
//Staigen
ante1
Jan 24, 2004
4,138
Hi sssaaa,
Why to you ask these simple questions?   ???
MP1
Dec 7, 2003
3,399
sssaaa,
Post a link to the project.
MP
sssaaa
Feb 3, 2006
74
HERE IS THE LINK OF VHF AMPLIFIER.
http://www.electronics-lab.com/projects/rf/009/index.html
I M USING IT FOR FM RADIO DIXING IT WILL WORK OR NOT?
Staigen1
Oct 26, 2003
695
Hi
Its not that simple, the question can't be answered that easy.
It might work or it might not work!
What is your antenna for instance? And how far is the radio stations?
The power they transmit at? Your topology?
Nothing can stand up against a good antenna arangement!
You should start there, if you dont already have done that.
The amplifier you linked to is the one that have the miller integrators.
I belive the other two is better, but i am not sure.
//Staigen
sssaaa
Feb 3, 2006
74
thanks staigen
u know any link of any other good vhf amplifier for FM DXing?
SM2GXN
Feb 18, 2006
161
Hi sssaaa!
As Staigen correctly stated, a good antenna for the band to cover is the best way to start.
A good advice is, make som kind of rotatable antenna and add an RF-amp for weak signals that is just above the noise level.
SM2GXN
Feb 18, 2006
161
If your wish is to start by building an RF-amp check the attached PDF-file
VHF-UHF_Amp.pdf
  • VHF-UHF_Amp.pdf
Staigen1
Oct 26, 2003
695
Hi
Can you describe your antenna and topography?
Isn't the other two good enough?
Here are the links:
http://www.electronics-lab.com/projects/rf/003/index.html
http://www.electronics-lab.com/projects/rf/022/index.html
And you got one from SM2GXN
Hey SM2GXN, what do you think of using miller integrators as VHF amplifiers?
You, if anybody should know about this!
//Staigen
sssaaa
Feb 3, 2006
74
hi staigen
i m using yagi tv antenna.
Hey SM2GXN, yours pdf file is not opening in my computer.
you have any web link of this file?
Staigen1
Oct 26, 2003
695
Hi
A TV antenna is not tuned to the FM band, and is not very good for DX-ing
at FM! Was the other two amplifiers not good enough for amplifying the signal?
It opened nice here, its an article from an australian mag, with an antenna amp.
Do you have Acrobat Reader installed?
//Staigen
sssaaa
Feb 3, 2006
74
i didnt check the other two amplifiers.
but i also check this
http://www.uoguelph.ca/~antoon/circ/activefm.html
but not with 2570 transistor because it is not avaible here i use 2N5179.
and i use telescope antenna for this circuit.
this circuit is also not working. Is this circuit is correct?
yes i have
Staigen1
Oct 26, 2003
695
Hi
Isn't that one similar to one of the amps here on this site?
You cant use a simple telescope antenna for DX-ing!
The circuit seems to be a working circuit, but aso check the
cirquit, that is similar, here at E-Lab.
And use a good antenna, else you won't be hearing anything!
//Staigen
