voltage across 2 terminals of diode,transistor
vamshi1
May 4, 2006
11
when we measure the voltage across  2 terminals of a diode using a multimeter
what does it show ?
similarly with any 2 terminals of transistors
what does these indicate??
audioguru2
Apr 6, 2004
12,026
It shows that the diode or transistor's junction is working properly.
When it is forward biased and conducts, then the voltage is about 0.7V and when it is reverse-biased, then it doesn't conduct. The forward voltage changes a little with current and with temperature. When it is very hot then it conducts a little leakage current when reversed biased.
