Voltage divider calculation using superposition
MRW
Hello!
I have this simple voltage divider circuit:
VCC
| |R1
---- V_OUT
| |R2
VREF
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
First I found V_OUT using the traditional way and got the following
relationship:
V_OUT = VREF + (VCC - VREF) * (R2 / (R1+R2))
Just for the heck of it, I tried superposition. I first shorted VREF
and go the following:
V_OUT1 = VCC * (R2 / (R1 + R2))
Then, I shorted VCC:
V_OUT2 = VREF * (R1 / (R1 + R2))
So, V_OUT = V_OUT1 + V_OUT2 .... but I can't seem to simplify it to
what I got using the other method.
Any insights?
Thanks!
John Popelish
MRW said:
Hello!
VCC
| |R1
---- V_OUT
| |R2
VREF
relationship:
V_OUT1 + VOUT_2 =
VCC * (R2 / (R1 + R2)) + VREF * (R1 / (R1 + R2))
add and subtract VREF * (R2 / (R1 + R2))
the subtracted term turns the first part into:
(VCC - VREF) * (R2 / (R1 + R2))
and the second part into:
Vref * (R1 / (R1 + R2) + VREF * (R2 / (R1 + R2))
which simplifies to:
VREF * (R1 + R2) / (R1 + R2)
VREF
And both parts together are:
VREF + (VCC - VREF) * (R2 / (R1 + R2))
The reason this is hard to arrive at is that the goal is not
the simplest form, which is more like:
((VCC * R2) + (VREF * R1)) / (R1 + R2)
MRW
John said:
V_OUT1 + VOUT_2 =
VREF
The reason this is hard to arrive at is that the goal is not the
Thanks again, John!
Jonathan Kirwan
VCC
| |R1
---- V_OUT
| |R2
VREF
relationship:
Any insights?
You've already got a good post or two on this. My own personal view
of 'superposition,' is more like how Spice looks at it. And as a
mental model, I think it's a little better than the 'shorting'
approach you used. I'll explain a little.
Take some circuit:
,----Vx
R1 | R2
V1----/\/\--+--/\/\----V2
R3 /
V3
The way I look at it is to think of the voltage as both "spilling
into" and "spilling out of" the Vx node.
First, look at the inward spilling situation. V1 spills into Vx via
R1. V2 spills into Vx via R2. V3 spills into Vx via R3. To set this
up into an expression, take the resistances as conductances and we
then have: V1*(1/R1) + V2*(1/R2) + V3*(1/R3). In other words, V1
flows through conductance 1/R1, V2 flows through conductance 1/R2, and
so on.
Second, look at the outward spilling situation. In this case Vx
spills outward via the same conductances. So we then have this
expression: Vx*(1/R1) + Vx*(1/R2) + Vx*(1/R3).
Inward spills are superimposed upon the outward spills and, since we
know that electons aren't accumulating at node Vx, the net
accumulation of charge at Vx must be zero. This means:
V1*(1/R1) + V2*(1/R2) + V3*(1/R3) = Vx*(1/R1) + Vx*(1/R2) + Vx*(1/R3)
or,
V1*(1/R1) + V2*(1/R2) + V3*(1/R3) = Vx*(1/R1 + 1/R2 + 1/R3)
This is easily solved for Vx, as:
Vx = (V1/R1 + V2/R2 + V3/R3) / (1/R1 + 1/R2 + 1/R3)
I chose a somewhat more complex case, just to point out that it's
pretty easy to see what is going on in more complex situations.
In the case of two resistors, this is:
V1*(1/R1) + V2*(1/R2) = Vx*(1/R1 + 1/R2)
Which becomes:
Vx = (V1/R1 + V2/R2) / (1/R1 + 1/R2)
Multiplying through by R1*R2/(R1*R2), you get:
Vx = (V1*R2+V2*R1) / (R2+R1)
Now, this isn't exactly your equation, which takes a different form.
But it is algebraicly identical to it. You can see that with simply
algebra.
Let's take your expression:
and replace some of the terms with my above briefer terminology. In
other words, as this:
Vx = V2 + (V1 - V2) * (R2 / (R1+R2))
Now, let's see if I can transform what I wrote above into that one.
Vx = ( V1*R2 + V2*R1 ) / ( R1+R2 )
= V2 + ( V1*R2 + V2*R1 ) / ( R1+R2 ) - V2
= V2 + ( V1*R2 + V2*R1 ) / ( R1+R2 ) - V2*( R1+R2 ) / ( R1+R2 )
= V2 + [ ( V1*R2 + V2*R1 ) - V2*( R1+R2 ) ] / ( R1+R2 )
= V2 + [ V1*R2 + V2*R1 - V2*( R1+R2 ) ] / ( R1+R2 )
= V2 + ( V1*R2 + V2*R1 - V2*R1 - V2*R2 ) / ( R1+R2 )
= V2 + ( V1*R2 - V2*R2 ) / ( R1+R2 )
= V2 + ( V1 - V2 ) * R2 / ( R1+R2 )
I think you can see that this is the same thing.
Anyway, that's how I prefer "seeing" superposition.
Jon
me
V_OUT1 + VOUT_2 =
VREF
or you can arrange the first equation to get the second...
= VCC * (R2 / (R1 + R2)) + VREF(1 -(R2 / (R1 + R2)))
= VCC * (R2 / (R1 + R2)) + VREF( (R1+R2)/(R1+R2)) -(R2 / (R1+R2)))
= VCC * (R2 / (R1 + R2)) + VREF * (R1 / (R1 + R2))
MRW
VCC
| |R1
---- V_OUT
| |R2
VREF
relationship:
Any insights?
Take some circuit:
,----Vx
R1 | R2
R3 /
V3
so on.
or,
Which becomes:
algebra.
Jon
Thanks, Jon! Very nice. I'm also looking for alternative ways to
perceive a method. Just with the help of this newsgroup, I think I've
slowly adapted to some "circuit seeing."
Jonathan Kirwan
Thanks for the kind comment. And I hope it does help a little. The
concept is broadly applicable, and may help in 2D resistive surfaces
and 3D resistive volumes with point voltages introduced on or within
them.
Jon
