Voltage Multiplier
Cloink
Nov 23, 2004
9
Thanks for all your responses but PLEASE could you answer the questions Q1 - Q3 directly? (I've got Q4 now.)
Of course I can't increase the power output by multiplying the voltage, but if the multiplier is only a half-wave multiplier then I can only presume it will have a poor efficiency.
Yes I'm sure it's AC, it's a motor in reverse. (Not that that necessarily means it's AC output, but it I've tested it, it is definitely AC.)
The 6V/0.5W dynamos are hugely restrictive (you must have noticed how much more effort it takes to cycle with it engaged), in this age of high-output LEDs, I'm convinced I can make something wind-powered that can at least trickle charge my rechargeable batts or hopefully if I'm lucky just power an LED-light directly, keeping a reserve in a large capacitor for when you're stopped at traffic lights, etc.
I'm hoping for something like 10V 50mA, so that would be 1/2W.
Thanks in anticipation,
Clark.
audioguru2
Apr 6, 2004
12,026
Hi Clark,
I still think your motor/dynamo has a DC output. An AC motor usually doesn't have the required permanent magnets to make it a generator. The alternator on a car uses battery power to make magnetism for its field coil.
Why multiply the voltage to drive a 2V LED? With a 10V output you'll be throwing away 8V which is 80% of the dynamo's power. 50mA is too much current for an ordinary LED unless you divide the current among a few LEDs.
What will limit the dynamo's current when you pedal fast into a strong wind? The LED will burn out.
How much wind resistance will a big windmill propellor cause? I bet it will have the same or more resistance as pedalling a dynamo. Try pulling an umbrella or parashoot around.
Answers to your voltage multiplier questions:
1) Sure you can use your electrolytic caps. You must connect them with the correct polarity. The voltage in your application isn't very much.
2) We have shown half-wave voltage multipliers. You are correct, an AC generator will be more efficient with a full-wave multiplier.
3) Full-wave multiple multiplier? I dunno, why not just use a transformer or a generator with a higher output voltage? Add gears or pulleys?
Cloink
Nov 23, 2004
9
Thank you, very much appreciated!
It's a brushless motor (from a pc-fan) - I will triple-check when I get a chance but my multimeter gave very spurious results when I connected it in DC-mode, but very consistent results when connected in AC-mode (of course, this was when I was blowing on the fan blades to turn it).
I have already attached the fan/motor/dynamo to my bike and seen the blades turn - it's about 4" dia (same size as a pc-fan obviously!) Yes, there'll be more resistance when I connect a load on it, but I still think it will turn, if more slowly. But no, there will be negligble extra wind-resistance from the fan/dynamo.
I need 10V+ because I have a vast array of LEDs, 3 in series x14 sets in //. They are 3.2V/30mA rated: that's 9.6V plus a bit for the drop across the resistors. This already works with a 10.5V supply (8 rechargeable NiMH AA batts). The whole setup draws c.350mA when connected.
Honestly, I do, mostly, know what I'm doing, I just can't get my head round the voltage multiplier circuit.
Many thanks again,
Clark.
audioguru2
Apr 6, 2004
12,026
Hi Clark,
Are you serious?
You're going to power 42 LEDs (a traffic light?) with a 4" PC's fan?
Ha, I figure that to develop nearly 4W of wind resistance (which won't be neglegible) the little fan will need a wind nearly the speed of sound! You'll need to step its voltage down, not up, to get your required 1/3rd of an Amp. Maybe you could put a big venturi in front of it to funnel lots of air to it.
BTW, the PC brushless fans that I've seen operate on 12VDC.
Never mind the LEDs. Use the fan to charge a battery when you ride downhill. Then let it propel you uphill. ;D
Cloink
Nov 23, 2004
9
Please please read the postings properly.
I'm sorry, I know I'm really a guest on this site, and I do appreciate all your help, but I'm quite exasperated that you haven't read my points.
I want to trickle charge the batts from the dynamo, I DO NOT expect to get 4W of power from the dynamo. Depending on how much power I CAN generate, and I'll keep you posted when I've got it working, then maybe, just maybe, I can generate enough power to trim my batts down from AAs to AAAs without having to recharge them after every 2 hours' use. If I'm REALLY lucky - and if I can find a full wave voltage multiplier circuit that more than doubles the p.d. - then I may just drag enough power out of the dynamo to power a lesser LED array in which case I'll have a rethink.
Yes the PC fan motor started life as a 12V DC motor, but I've taken the PCB off it and I'm just taking the 'raw' AC output it generates in its new 'skeleton' mode.
I am also quite well aware that I need to regulate my eventual DC output -- the dynamo will of course provide a different p.d. depending on how fast I'm going, so I have to multiply it up maybe 4 or 5 times so that when it is - and I am - going slowly I still have the 10V I need. When I'm going faster, this multiplied voltage will be way too high, so yes, I need to step it down. I have found circuits elsewhere that show me how to tap off a constant voltage.
Is there any other unsolicited advice you'd like to give me? I only asked a few simple questions.
Regards,
Cloink.
audioguru2
Apr 6, 2004
12,026
Hi Clark,
I am sorry to have sounded so pessimistic about your idea, but I don't think a 4" fan will provide much power at bike speeds.
When you said you needed 350mA at 10.5V to power a 42-LED traffic light, I didn't realise that your Ni-MH rechargeable battery will be supplying most of the power.
I am also sorry that you may not be aware of this additional unsolicited advice:
1) A voltage doubler (tripler, etc.) is designed for a mains voltage input, that's why its caps have such a high voltage rating. If your dynamo has a peak output voltage of only 2.0V, the voltage drops of the two diodes in the 1st half-wave voltage doubler will allow it to have an output voltage of only 2.2V to 2.6V. The 2nd doubler will have an output voltage of only 2.6V to 3.8V, etc. After these two doublers you still haven't yet doubled the voltage but you have quartered the output current. The dynamo provides 2.0V at say 0.1A (200mW) in, and you get only 2.6V at only 25mA (65mW) out. That is only 33% efficiency before deducting ripple voltage.
2) Your dynamo probably has at least 3 coils which will have outputs on different phases. I think that each coil must have its own separate voltage tripler, quadrupler, etc. before being combined at the output. It will require many diodes and capacitors.
Cloink
Nov 23, 2004
9
Yes, thank you, that was very much more helpful and I will consider finding diodes with a lower voltage drop, or just looking for a different method - or maybe giving up altogether, after all, I've already got rechargeable batts.
But for interest, before I savaged the motor, it was a 'fancy' one which lit up when switched on - via 4 LEDs inserted in its casing. When used in reverse as a dynamo, with no other load attached, these 4 LEDs lit up as I cycled down the street and the fan turned. Yes, the LEDs were lower power output than the high luminosity ones in my 'traffic light' (as you have christened it), and there were less of them, but clearly there is SOME usable power being produced.
The motor/dynamo has 4 windings, and 3 terminals. 2 points are common and I'm taking the output from the non-common terminals, after finding that this gave the greatest (AC) p.d. My half-way understanding of the subject leads me to conclude that the common terminal is the 0V rail, and the non-common terminals are producing a simple AC wave. However, with no oscilloscope, these are educated guesses based on investigations with my multimeter, but either way, with no load, I can blow on the dynamo and register upwards of 8V AC across these terminals. Not for very long though - I start to go dizzy!!
I'm using this particular one because it was in the bargain bin and cost me all of 98p (GBP0.98). Being a brushless motor(dynamo), however, (and uses bearings, not bushes) I feel that it will be quite efficient at its job, plus it has the added benefit of already having a rather good fan attached, and a casing with points I can use to attach it either to my bike or the 'traffic light'.
I will return (maybe) when/if I can update you with my achievements or failures. Though I suppose it's more likely if I fall on the side of 'achievement' rather than 'failure'......
Many thanks again,
Cheers,
Clark.
Cloink
Nov 23, 2004
9
A site with a full-wave voltage multiplier of arbitrary factor if anyone else was looking for one....
http://members.tm.net/lapointe/Cockcroft_Walton.htm
audioguru2
Apr 6, 2004
12,026
Hi Clark,
Thanks for the link of the guy producing 64,000V! Where's Steven?
That guy doesn't care about the voltage drop across his diodes.
You might not need a voltage multiplier and its losses if your dynamo produces 8V when you blow it enough to get dizzy. Your meter probably measures AC RMS which means the peak voltage is 11.3V. After rectification, you'll get 10.5VDC. It will probably sag with a load and the fan will slow down but it is worth trying.
Why not test the dynamo with a load and voltmeter while you are holding it out the window of a moving car (let someone else drive)? Record different loads and speeds. Record the loads and speeds when its unloaded output voltage drops to half. Please let us know the results.
Kevin Weddle
Feb 23, 2004
1,620
There is an update to my numbers diagram. I forgot that the negative cycle does indeed show up because the first capacitor is clamped at 10 volts. The fist diode will remain reverse biased and you get the complete cycle which is passed through the capacitors.
MP1
Dec 7, 2003
3,399
Hi Clark,
Welcome to the forum.
The little power plant from a computer fan sounds interesting. I hope that you will continue with the project. Is it possible for you to display a drawing of what you have made? I am sure others will take an interest. Please do not be discouraged from comments posted by others. Wind power is a good way to get a trickle charge. You might find that these computer fans all give different outputs. Have you looked at the signal on a scope? You might not have a sine wave. It is very likely that you have a pulse or square wave, which will give you different results as well.
Good luck!
MP
Cloink
Nov 23, 2004
9
First things first. audioguru was right to have reservations about how much power the fan/dynamo can produce.
When blowing on it, taking the output directly into a bridge rectifier and not into the multiplier, I can keep a single high luminosity LED lit. On the other hand, a fully charged 2200 micro-F cap does not keep the LED lit for a significant amount of time (i.e. not long enough to sit at traffic lights) [if I remembered all the equations from school I could have worked that out!]
So - regardless of whether my dynamo can create enough power to light up the LED(s), I'd need some stonkingly large caps to keep them going while I'm stopped. Back to my rechargeable batts then.**
My crude calculations suggest I can get about 10-40mW from the dynamo. Let's say 1mA @ 20V. Doesn't really seem worth the hassle trickle charging the batts either, it's gonna take a long time to put any significant charge into 750mAH AA's.
I do have a slightly different question though, if anyone's still reading (!).
My battery charger registers, for the sake of argument, 1.4V when charging a batt that when isolated registers 1.3V. Now I've convinced myself of this, but could someone confirm?
With the battery in the charger, the charger MUST have a driving potential of 2.7V mustn't it? Because the driving potential from the battery is fighting against it.
Back to a possible trickle charging dynamo. To charge a 10V battery pack, I guess I need to generate a driving potential of 20V (or so).
Although the v-multiplier worked with no load, as soon as I attached a load, the voltage dropped drastically (almost to zero!) Am I right in thinking the lower the capacitance of the caps in the v-mulitiplier, the less will be the voltage drop (if at the expense of a higher ripple)?
Anyway, in conclusion, I think the output from a wind-powered dynamo is too small to be really worth utilising.
**One could maybe attach a (well balanced) weight to the dynamo so that when stopped the angular momentum kept it going... But that's mechanics not electronics!
MP, sorry, no diag, there's not really one to talk of. I simply rectified the dynamo output with an off-the-shelf bridge rectifier. The v-mulitiplier circuit is already on this site. In both instances I just connected the AC out from the dynamo to whichever circuit.
Also, no, I have no oscilloscope and am not likely to have access to one so I can't investigate the exact waveform of the AC.
Thanks everyone.
Cheers,
Cloink.
audioguru2
Apr 6, 2004
12,026
Hi Clark,
I am sorry that your generator project didn't work.
But I am glad you realise that if the fan was large enough to create the same wind-resistance to your cycling effort as a mechanical dynamo, then you wouldn't gain anything.
I am also glad that you realise the huge size required for a "supercap" to provide LED current for any length of time.
Small capacitor size is the same problem with the voltage multiplier.
Answers to your new questions:
1) You are correct, a Ni-Cad or Ni-MH rechargeable cell's voltage peaks at about 1.4V when fully-charged and is still charging at 1/10th the current of its A/hr rating. The charger's voltage must be higher than the battery's voltage so that current is continuing to flow into the battery. Each cell's voltage will quickly drop to about 1.25V to 1.3V after being removed from the charger without a load.
2) Since each cell needs only about 1.4V to fully charge, a higher voltage would be required if you used a normal current-limiting resistor, so the extra voltage is lost across the resistor. Ohm's Law says the voltage across the resistor determines the charging current. I don't know where you got a voltage of 2.7V. Maybe your charger produces 2.7V (without a battery cell) and loses the extra 1.3V across its current-limiting resistor.
3) If the generator doesn't produce too much current, it can be connected directly to the battery, but use a series diode to keep the battery from discharging into the generator when it is slow or stopped. The extra generator voltage will be lost across the generator's internal resistance, and 0.7V to 0.9V will be lost across the diode.
4) Ni-Cad and Ni-MH battery cells are usually rated at 1.2V with a reasonable load. So your "10V" battery will have 8 cells and be rated at 9.6V. To provide 1.4V per cell, its charger must have at least 11.2V plus extra voltage for its current-limiting resistor.
5) Some battery manufacturers (excellent info at www.energizer.com ) recommend a maximum continuous "trickle-charge" current that is only 1/25th the battery's A/hr rating. They assume the trickle is not for charging but for keeping a fully-charged battery above self-discharge.
6) With small caps in the voltage multiplier and a high current load, the ripple voltage is maximum. With much larger caps or lower load current the ripple voltage will be much less because the caps will be big enough to provide the current between input half-cycles without the voltage dropping too much. The input current will be multiplied by the multiplier amount.
Have you considered using Ni-MH cells for powering your LEDs? AA cells are available with 2200A/hr ratings.
audioguru2
Apr 6, 2004
12,026
OOOps,
You could propel the bike and tow a huge trailer for weeks if AA cells were rated at 2200A/hr.
They are actually 2200mA/hr. Sorry.
Cloink
Nov 23, 2004
9
Hi audioguru
Thanks for all your time - you've still missed some of my points though. I already have 8AA's in use for the circuit. My hope was to reduce the AAs to AAAs (to save weight and also 'cos the AAAs would fit in the casement in which the LED array is housed whereas 8 AAs don't). Of course I can do this but I'll only get around 2hours usage instead of 8 or so as the charger won't make a significant difference.
I'm fortunate enough to have a dad who sells rechargeable batts so I'm ok on that score!!
The batts are indeed rated at 1.2V (some at 1.25V), but even when in use, the 8 together still registered over 10V using my multimeter (even as high as 10.5V), this was at c.350mA.
I still however believe that, given a clean design sheet, one could manufacture a wind-powered dynamo-and-LED light set. As I mentioned, the crude arrangement I had was enough to power one high luminosity LED - not much I know but this was from cobbled together bits and bobs from someone who doesn't really know what they're doing. Obviously I'll have to wait 'til I'm a millionaire and I can commmission someone to make one for me!
Finally, I'm sure you've picked up on this, but with a diode in place to prevent the batts draining through the dynamo, the small current that the diode allows in reverse would surely be enough to negate any output from the dynamo in the first place, especially if left connected when not in use.
Anyway, I've fallen out with the whole project, 3 of the LEDs have stopped working (presumably blown) and I've lost the battery pack which had my 8 AAs........... Oh dear.
Cheers,
Clark.
audioguru2
Apr 6, 2004
12,026
Hi Clark,
Now is the time to replace the old low-capacity 750mA/hr AA Ni-Cad cells that you lost with tiny but modern high-capacity 850mA/hr AAA Ni-MH cells (Energizer have them). You are lucky that your dad can give them to you!!
The reverse leakage current of a silicon diode at your low voltages is so low that you can hardly measure it with extremely sensitive equipment. The 10 femto-amperes of leakage current from a cheap 1N4002 diode will discharge your new 850mA/hr battery in 9,703 years! A slightly more expensive but higher voltage rated 1N4007 diode will leak even less.
D ;D ;D
