Voltage rating of wire
ElectronicsR
Mar 23, 2016
72
If we increase current in wire it burn if we increase voltage what will happen in small zero pcb wires??
14,317
The voltage withstand capability of a wire does not depend on the thickness of the wire. The thickness of the wire is only relevant for the max. current it can carry.
Responsible for the max. voltage that can safely be applied to a wire is the insulation (thickness, material). Generally:
  • A wire with thick insulation can withstand a high voltage regardless of the thickness of the wire.
  • A wire with thin insulation can withstand a only low voltage regardless of the thickness of the wire.
'wires' on a PCB (called traces) are not extra insulated (solder stop coating is not a valid insulator). Therefore you neeed to increase the distance between wires when the voltage between them increases. There are several standards covering these requiremenets, notably EN/UL 61010-1.
ElectronicsR
Mar 23, 2016
72
Thanks for reply.
So, in large kv rating wire what type of insulation we need?
and why insulation is important for higher voltage, does electron cross the insulation?
Minder
Apr 24, 2015
3,561
High Kv cable requires a suitable insulation to prevent breakdown, if you go to the Cable manuf sites, they usually have technical information on their respective cable ratings.
Beldon is one such large manuf.
M.
duke37
Jan 9, 2011
5,364
If you look at the wires in a telephone cable you will see that they are fairly thin. Mains cables are thicker and have a secondary insulation layer. Car ignition cables are much thicker than either. It is all due to the voltage in the wire.
Polyethelene is a common insulation, if you are rich, you can go to PTFE.
14,317
Sorry to disagree, but in this case the wire thickness or diameter is due to the current, not the voltage. A telephone cable carries a minuscule current comparet to the high current a car's wiring has to provide during e.g. a cold start of the engine.
14,487
primarily, duke is referring to the thickness of the insulation in which he is correct
just wasn't worded as clearly as it could have been, but I understood what he was getting at
and with that it is all related to the voltage in the wire that needs to be isolated/insulated :)
14,317
Sometimes it shows that i'm not a native English speaker :p
But why should the insulation of a car's wiring (@12 V) be thicker than the insulation of a mains cable (@115 V or @230 V)?
14,487
specifically he said "cars ignition cables" and I immediately thought of the wires between the coil to distributor and sparkplugs
where the insulation is very thick .... many kV's and relatively low current
duke37
Jan 9, 2011
5,364
Yes, I did not describe the wire diameter in a clear way. Harald is better at english than most native speakers.
Interestingly, car starter connectors are always known as cables not wires.
I think that the insulation of the wiring of cars or combine harvesters has to not only provide isolation but also to withstand vibration, a robust covering is then necesary. Flexible mains cables have a secondary insulation covering. In the past single insulated twin bell wire was adequate.
Recently, I have been winding a coil using wire, not cable even though it has insulation on it.
Edit:
I just had a look at the thread title, it is "Voltage rating of wire"
Minder
Apr 24, 2015
3,561
thanks for reply help
Incidentally just in case you might think of using Automotive Hi tension plug wire the conductor can vary in composition.
The vast majority of cores are conductive carbon wrapped with fine copper wire. Other cores wrap wire around a magnetic material.
Conductive carbon can break down over time,
Older autos had actual copper conductor.
M.
