1000V DC 25Amp voltage regulator
hans_dutch
Jan 18, 2023
I need to adjust power based on a input of 0-10v/4-20mA @ 1000v DC. max 25 Ampere.
The drain are heat coils. I wanted to differentiate the load in kW by playing with the voltage.
But I can't find an easy solution for it. Does anyone has any experience with this? I could use a freq converter but this is quite expensive.
I do the same with AC 400 volt with a simple unit something like this one:
https://www.elektrisch-verwarmen.com/SCR power regulator 3fase 0-10.pdf
14,317
Look up "pwm". A switched mode power control method.
At 1000 V / 25 A a linear regulator is imho out of the question.
hans_dutch
Jan 18, 2023
Hi Dana & Harald! thank for you input, littelfuse can't do anything sadly.
Harald. PWM is perfect.. it doesnt need to be linear as long as we can control the steps.
Do you know players in the market who have PWM 1000v DC / 25amp regulators?
Hans
