voltage standard
twister
Feb 12, 2012
172
I would like to find a way to accurately set my voltmeters, especially on DC. I have several and they are all different. :)
Resqueline
Jul 31, 2009
2,848
There are many 'precision voltage reference' IC's available, just Google that expression.
Examples: REF01, REF102, MAX674, MAX676-678, LT1031, etc..
shrtrnd
Jan 15, 2010
3,903
They're not cheap, but there are a lot of electronics standards labs available that
calibrate test and measurement instruments to factory specs.
twister
Feb 12, 2012
172
For my cheap harbor freight multimeters, it would be overkill. ha
I don't know why I didn't think of it before, but when Resqueline mentioned those voltage standards, I thought a regulator IC would be close enough. So I found a 6 volt regulator in my junkbox and hooked it up and set all my multimeters. Sometimes the answer is so simple that you can't see it. I couldn't see the forest, for the trees! ha
I just built a solar panel voltage regulator and I had 5 meters hooked up to the breadboard at the same time. It was confusing when they all were at least a volt off, but now that I'm done they are all reading the same except one, and it won't adjust. I probably had it on the wrong range at one time or another and ruined a resistor or something. They aren't protected from people like me. :eek:
shrtrnd
Jan 15, 2010
3,903
I work in a standards lab.
Believe me, even the best of meters aren't protected from some of the damage I
see, done by 'experts'.
JMW
Jan 30, 2012
90
shrtnd:
It takes a professional to really do a number, it takes experience and ingenuity to create smoke.
There was a Air Force A school instructor from the '60s who had the correct response. " the quality of the technician in the field is inversely proportional to the amount of damage he did in class. I did have exception to this. Sent an E5 to school on a searchlight, he was so bad, the school wouldn't accept any further applicants from our ship for a year. This field is an ongoing learning experience. When I started common voltages were 10k, not only could release big smoke, but you could get hurt.
