voltage transfer (my 6.002x homework)
kbcheong
Mar 24, 2012
25
In this diagram, in order to calculate the voltage transfer ratio, I use the impedance to calculate vo/vin, if the impedance for vo = L + 1/Cjw and for vin = R1, what about R2? is it part of vo or vin?
14,293
To calculate Vo make an equivalent circuit consisting of a voltage source Veq and an equivalent impedance Zeq. Veq and Zeq can be computed from Vin, R1, L and C without using R2.
Hint: consider the cases R2=0 Ohm and R2=oo Ohm to arrive at the necessary equations.
Use this equivalent circuit and insert R2. You now have a common voltage divider and you can easily calculate the transfer ratio.
Harald
By the way: You've been given a lot of help in this forum during the last months. It would be nice to get some feedback, too, once your question has been answered.
Why don't you help us more by giving us the full question from your homework.
You know, the one that begins:
The inductor and capacitor in the diagram below are part of the output-coupling network of a radio transmitter. The rest of the transmitter (the source of radio-frequency energy) is represented as a Thevenin source, and the antenna load is represented by a resistor.
And why didn't you put this in the homework section?
