Volume Pot cleaning Spray
Joe G \(Home\)
Hi All,
I am look for some to purchase the magic volume pot cleaning spray.
What do you recommend?
and Where to get in Melb?
Thanks in advance.
Joe
atec 7 7
Joe said:
Hi All,
Thanks in advance.
Joe
Dick Smith or Tandy/jaycar knob cleaner ..
Any decent electronics store should have some
Joe G \(Home\)
Thanks for your speedy reply... I uesd to work for DSE for 5 years in sales
and the sevice department, about 15 years ago.... back then , there was
specific Electrolube brand for pots.....as some of the other
sprays can damage the pot and leave residues..
I have already searched the DSE web site and the CRC spays come to
light..... however... there is no specific mention,"suitable for Pots".
Do you have a specific brand, part No, Model name and number of a volume
pot cleaner?
Thanks in advance.
Joe
Joe G \(Home\)
sales and the sevice department, about 15 years ago.... back then , there
was specific Electrolube brand for pots.....as some of the other
pot cleaner?
Thanks in advance.
Joe
Herrs and online thread on cleaning pots..
http://www.ovationfanclub.com/cgi-bin/ubb/cgi/ultimatebb.cgi?ubb=get_topic;f=2;t=016429;p=0
Looks like a may may need to replace these pots..
Joe
K
KR
pot cleaner?
Thanks in advance.
Joe
I have used CRC 2-26 before without problems, but a purpose made pot
cleaner - if available - is probably preferable..
Of course it wont help if the pot's carbon track is worn out or has a
"dead spot"
Phil Allison
"Joe G (Home)"
** Go ask your nearest Tooth Fairy supplies store
- fuckwit.
** See above.
** Why post such a damn stupid question ?
Only demonstrates how fucking wankers like YOU don't want to take ANY
advice from anyone.
...... Phil
atec 7 7
pot cleaner?
Thanks in advance.
Joe
Still using the carton I bought at ds a decade ago. so no cant help
you know about google ?
Eeyore
Joe G (Home) said:
Hi All,
If the 'track' is damaged no amount of spray is going to help you. What
are the symptoms and what is the equipment, type and value of pot ?
Graham
Phil Allison
"Eeysore = Pig Ignorant Pommy Moron "
Joe G (Home) said:
Usually the case.
** ROTFL
Graham Stevenson would not know if his fat arse were on fire.
...... Phil
Eeyore
** ROTFL
Tried cleaning a sealed Alps or Taiwan Alpha pot ?
Graham
Phil Allison
** Tried sticking you head up a dead moose's bum ?
Wot a steaming great POMMY FUCKWIT !!
...... Phil
Adrian Jansen
Joe said:
Hi All,
Thanks in advance.
Joe
If its an audio control, and its 'crackly' that is a sign that its
getting DC current through it. So its well worth checking any
capacitors around the pot, and ensure they are not leaking DC current.
Old electros are well known to do this. And after you replace the
electros, you may still have to replace the pot to get rid of the noise.
Regards,
Adrian Jansen adrianjansen at internode dot on dot net
Design Engineer J & K Micro Systems
Microcomputer solutions for industrial control
Note reply address is invalid, convert address above to machine form.
Phil Allison
"Adrian Jansen"
If its an audio control, and its 'crackly' that is a sign that its getting
** A rather unlikely possibility.
It takes only seconds to apply some spray cleaner/lubricant to the track and
wiper of a " noisy " pot and so **immediately resolve** the question of
whether a particular pot merely dirty.
Like 99% of them ARE !!!!
So you do that step FIRST and only consider other steps if it proves
unsuccessful.
...... Phil
Mr.T
Yes leaky caps can cause a problem, but if you still have to replace the
pot, then DC leakage wasn't the only cause in the first place obviously,
unless the current was enough to destroy the pot. That's not very common
IME.
MrT.
Ross Herbert
:Joe G (Home) wrote:
:> Hi All,
:> I am look for some to purchase the magic volume pot cleaning spray.
:> What do you recommend?
:> and Where to get in Melb?
:> Thanks in advance.
:> Joe
:If its an audio control, and its 'crackly' that is a sign that its
:getting DC current through it. So its well worth checking any
:capacitors around the pot, and ensure they are not leaking DC current.
:Old electros are well known to do this. And after you replace the
:electros, you may still have to replace the pot to get rid of the noise.
Adrian, I note the "design engineer" tag on your post but you don't seem to be
aware of why pots get "crackly". Inside a potentiometer there is a wiper which
makes contact with the resistive element and every time you move the wiper it
attempts to dislodge some of the resistive material. The more oftern the wiper
is moved the more material gets dislodged. It is these dislodged particles of
resistive material which cause the noise in 99% of cases. It is NOT necessarily
(in fact, rarely ever) because they have DC flowing through them.
High quality pots such as Alps etc are costly because they made to resist (no
pun intended) the dislodging of material. That's one reason they are expensive.
atec 7 7
** ROTFL
..... Phil
You however would being a bottom
you know I am right philthy
Phil Allison
"Ross Herbert"
Adrian Jansen
to be
** It's a very deep mystery to sooooo many out there .....
it
wiper
of
** The wiper mechanism would easily move tiny carbon particles out of the
way ( ie like a road grader) - if it were not for the fact that nearly
all pots and faders (ie slider pots) are packed with grease to improve the
mechanical " feel " when operated.
This grease has the bloody horrible habit of migrating onto the surface of
the resistive track AND moving metal parts over time - so mingling with
and compacting the carbon dust into a thin layer of *non conductive* gunk.
It is this **gunk** layer that must be removed to restore good operation
to a "noisy" pot.
Products like WD40 do it so damn fast and well, it makes your head spin.
** True, not only because leaky electros are nowadays a rarity - but
that it is very rare now to see coupling electros subjected to any
significant DC voltage at all.
Dual +/- supplies have long been the norm in all ( non valve) audio gear
so there is simply no DC voltage to block.
..... Phil
