Want a 4400uF 50WVDC Capacitor
Status
Not open for further replies.
RFamateur
Oct 15, 2009
10
Hey, so I'm building a dual polarity power supply and I'm having the hardest time finding the capacitor rating I'm looking for.  I was under the impression this capacitor was fairly common but after digging around it seems to be really hard to find.  I have found 4700uF electrolytic capacitors with a 50 volt rating, but pretty much no 4400uF capacitors.  If anyone has any suggestions on a good place to get these, than please don't hesitate.  Perhaps Jameco?
Hero999
Oct 28, 2007
2,433
You won't find a 4400μF capacitor because it isn't a standard value.
Capacitors are only normally made in E6 values (E12 if you're lucky), look up "preferred value' on Wikipedia for more information.
Just use 4700μF, the chances are it's just a typographical error.
audioguru2
Apr 6, 2004
12,022
For a power supply you want filter capacitors with the highest value you can afford or for a certain physical size.
Electrolitic capacitors have a wide tolerance of their value. The minimum value of a 4700uF capacitor might be 3760uF. A 4400uF capacitor might be only 3520uf and have a ripple voltage that is much too high.
RFamateur
Oct 15, 2009
10
Thanks guys that was most helpful. On a side note I have been fabricating an old CD player as the case for the power supply, but it's turning out to be more difficult than I originally thought.  Any suggestions on relatively cheap project boxes and the best tools to use for mounting switches, transformers, etc.?
Thanks!
Status
