Al
- Jan 1, 1970
- 0
Hello All (From the land Up Over!)
Recently bought "Krystal Clear salt water system " Model 8110 with the Intex brand.
It's a salt water chlorinator.
Ok .....The unit is on 110 V mains and consists of some electronics including a
programmable timer that
switches itself on and off as programmed.
What I want to do, is to have the chlorinator control the on off switching of my 220
volt pump so that I do not have to turn the pump on and off manually or run a
separate timer.
I have a suitable 110 volt relay to switch the 220 volt current to the 1.5 horse
pump. I don't expect the coil in the relay would draw much more then 10 or 15 watts
so there should be no problem drawing power for it from the chlorinator.
Does anyone know exactly how to do what I want to do. I myself have a terrible
track record on these electronic things. I usually make them smoke and once
the smoke comes out they never work again! (O:
Thanks in advance!
separate timer.
Thanks in advance!
