Wattage lowering
audioguru2
Apr 6, 2004
12,026
I doubt that your stereo puts out 72 Watts per channel. It is probably 72 Whats per channel.
Audio-video stores sell cheap L-Pad attenuators for speakers that soon burn out, and pretty good stepped transformers for adjusting the volume of speakers far from the amplifier. Use a stepped transformer, turn it down then remove its knob.
audioguru2
Apr 6, 2004
12,026
Its ad says, "72 watts x 4 peak power". Peak power is double the normal power which is 36 Watts x 4. But they don't say how much the amps are overdriven since they don't say the distortion so the power per channel at clipping could be only 14 Watts. Most car amps produce 14 Watts per channel at clipping into a 4 ohm speaker.
cntransportation
Jan 9, 2006
3
Yes front to rear fader will solve that problem but be carefull you dont forget and  and or let your buddys near it. I have to agree with one of your replys,,I cant see your sterio putting out that much either !!!
windoze killa
Mar 4, 2006
136
The 72W is probably 72W PMOP which basically translates to the O/P power just prior to melting. There is really only one power measurement and that is RMS. It would be handy if you can find out what the RMS power of this amp is. Would be much easier to say if the speakers will handle it. If the speakers are a decent brand then the power of the speakers is probably in RMS and can probably handle the amps O/P.
