What can i do with Quartz Crystals?
Electro132
Feb 12, 2013
261
Hi
i found this part in my kits and want to know what i could do with it. It is a 25 mhz quartz crystal. (pics are provided)
Any ideas? Could i use this in a circuit to produce waves, radar, telecommunications, etc.?
With an appropriate circuit you can make a 25MHz oscillator
14,311
No way.
1) a wine glass typically resonates at audible frequencies less than 20kHz
2) You won't find a speaker able to produce 25MHz sound.
Electro132
Feb 12, 2013
261
No way.
How about from an LD? you can put frequencies into LD's and make that produce sounds since it can transfer music wirelessly.
Electro123,
Do you ever read any of the responses?
Electro123. Here is how you break a glass with sound.
1) tap glass and make it ring.
2) record sound from glass
3) determine the dominant frequency
4) create a loud enough sound at that frequency and the glass will break.
14,311
Take the quartz, throw it hard against the glass. If you throw hard enough, the glass will break.
I'll pay that. Probably the easiest way too. It would be easier if you can find a larger crystal or a strong rubber band to accelerate it!
Solidus
Jun 19, 2011
349
You could always opt for the more efficient method.
Throw the glass at the crystal.
Yes, but building a rail gun to launch the crystal would be more fun.
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
You can use a quartz crystal to combine crystal healing with acupuncture. They actually operate in the same way anyway. Just get a confident sympathetic person to jab the leads into your body until the general vague ill-feeling is alleviated.
I see a book coming "101 Uses for a Dead Crystal"
