Steve Spence said:
That's only 500 watts or so. Trickle chargers.
Wrong. A electric car (GM's EV1 before they were destroyed) gets 120 miles
(193 km) to 16.9 kw/h (the batteries range when fitted with the original
lead acid batteries). Breaking that down gives about 87W/h per km. Assuming
the cells get 5 good hours of light a day (or a lot of moderate light), that
generates 2.5 kw/h per day, which is about 31 km's. That's some trickle
charger. Now, most electric cars may not be as efficient, but not far off
from that. I have calculated a typical high efficiency gas car to use about
150 W/h per km at the flywheel, which has many other parasitic loads such as
alternator, water pump, power steering, much more complex drive train, runs
when idle, needs to warmed up, FI and ign needs considerable energy, no
regenitive braking, poorer aerodynamics, etc so this is a very reasonable
number. Now, the biggest thing, is I don't see where 500 W of panels would
fit on a typical car unless it was a large station wagon. Panels imbedded
into the hood might posess quite a ascetics challenge, so the roof would be
the main collection area. Window tint could also be made with solar cell
technology.
BTW, a electric motor is rated different from an gasoline engine. a 20 hp
electric motor can produce 60 to 80 hp bursts of power, often much more. A
gasoline engine is rated at it's peak power. A 100 hp gasoline engine will
produce a maximum of 100 hp, and would self destruct in a short time if run
at full power continuously. GM's EV1 produced something like 140 hp or kw/h
of energy to the wheels. It was faster accelerating then most gas powered
cars (remember an electric motor is almost always in it's peak power range
and efficiency, where a gasoline almost never is), and a non governed
prototype hit 183 miles an hour.
At wide open thottle.
60hp is 46kw. you only have 500 watts of pv. see a problem here?
No, I don't. Read above. 60 Hp is not needed to maintain speed, only for
accelerating. Unless you plain on going down a highway at 200 km/h, or going
up huge hills (don't forget regenitive braking on the way down restores most
of the energy lost), 60+ hp would only be needed for a few seconds.
If the car drives 10 km, then 0.87 kw/h was consumed. Since 1 hp used for 1
h is 0.746 kw/h, and the car takes 1 hour to get there (10km/h), then only
1.16 hp is required to maintain speed. (note, assuming 100% electrical to
mechanical energy conversion - real case is usually better then 90%, and
since the 0.087 is a real number, the hp requirements would slightly
decrease). At 100 km/h, for 1 hour, 8.7kw/h would be consumed, and would
require a 11.6 hp source to maintain speed.
Note, this is neglecting the fact that air friction is a function of speed
squared, ie the faster you go, the air resistance increases at a rate of a
constant times the speed, and times the speed again. This means that the
force slowing the car down from air friction is about 100 times greater at
100 km/h, then it is at 10 km/h. GM's EV1 was likely rated at a reasonable
speed of 50 to 70 km/h. This means the above simple calculations mean that
the required hp level at 10 km/h is much lower then calculated, and higher
at fast highway speeds.
Ever stick together 10 to 20 9V alkaline batteries - that will produce
about 90 to 180 volts. Voltage is not a measure of battery size. Storage
capacity is.
these batteries weigh over 50lbs each. think again.
GM's EV1 had 16.9 kw/h of storage with the old lead acid batteries before
they switched over to NiMH, which brought the mileage up to 18- miles from
120. The lead acid battery bank weighed about 1500 lbs, if a remember
correctly. The voltage is in the order of 320 V.
Properly called an inverter. For a motor drive its called a VFD, short for
variable frequency drive. DC motors are outdated by this technology that is
more efficient, easier to control, and has nothing like commutators and
brushes to wear out. The motors are also very simple (although more complex
to understand, and the internal electronics are very complex, but easily
handled by cheap microprocessors).
Why? Separate motors do have their advantages for all when drive and
handling purposes, but for an every day generally vehicle, there is no need.
I like high performance driving, so I would prefer separate control on al
the wheels, but for the average 95% who want to get groceries and go to work
with their car, along with taking the family to uncle Bob's house don't care
for that much, especially if it adds more cost.
