WHAT PERCENTAGE
K
K. Jones
Jeff said:
Not anymore, as you also noted. See below. big numbers help sell stuff (to
morons!), and lying about hp makes bigger numbers.
Ummm, no. AFAIK, less than 1/2 dozen specific vehicles currently being
manufactured have, "questionable" HP ratings.
Don't take that as all or most. I simply stated there are a _few_
instanses.
Yes, that is true, however the electric motors can be safely "overpowered"
for several minutes. That may be a better term to discribe it. Gasoline
motors produce their max hp, and that's it - you cant produce any more
without modifications. There is another thing about more efficient use of
torque, discussed below.
Either you didn't read anything I wrote earlier, or we have a comprehension
problem.
HP=HP. Stating a continious duty number (and saying so), and stating a peak
number (and saying so), isn't "rating them differently".
The others are not racing motors. That was just one extreme example dumping
in more then 10 times the continuous rating.
Fine. But normally, like when driving down a highway, it is moving your car
with 20 to 40 hp. Anything more then that is not continuous. I doubt you use
275 or more HP for more then a minute or two?
Thirteen seconds+fraction, or 1/4 mile at a time, to be more specific
*smile*
I never claimed it took 275 HP to drive down the highway, why would you
imply that?
neither
The electric motors are designed for it. The only stress is heat build up,
unlike a ICE. Heat build up reduces the permeability of magnetic materials,
and therefore the power drops. If the heat gets too serious, the windings
can become damaged. In an 3 phase motor, the only moving part is a iron
core - hardly anything to break.
You intall controllers, and wire/fuse at 20HP electric motor for 60/80HP
duty??
Look at this EV motor manufactures ratings. This is typical of other
electric motor manufactures, however they are usually rated in kW usually
with a max rating and a continuous rating.
Exactly. The only difference is, auto manufactures don't give a "continious
rating", which would be much lower than the peak HP rating.
Muscle cars, Too bad I was not around for them. They were gone for decades.
Newer cars are not rated the same. Looks like you know what I mean from what
you wrote below, however since numbers sell, all the manufactures have to
lie at least a bit - high performance cars are generally a little more
accurate (but then the Camaro's and Firebirds had a slightly lower power
rating then the Corvettes with the same engine (same heads, cam, dual cat,
everything). Go figure). High performance cars used to be underrated power
wise, along with the speedometer, to help offset insurance costs.
It's called "de-tuning". Many ice's are "de-tuned" at the factory for
various reasons. That's what keeps various "performance chip" manufactures
in business.
I suspect the reason cited above would be marketing. Don't wanna piss the
guys who are buying your "premium" sports car (the vette) off, by offering
as "powerful" a plant in the "cheapie" sports package now, do you? *smile*
Check out the Tzero at AC propulsion's website. It's rated for 200 HP PEAK
(67 hp continuous), woops Corvettes, Ferrari's, Porsche's, Lamborghinis, and
with the LiION battery pack, it does 0 -60 MPH in 3.6 seconds, with a 300
mile range at 60 MPH.
http://www.acpropulsion.com/EAASV_101803.pdf
You didn't answer the question.
"What kind of electric motor is always in it's peak power, regardless of
speed or load?"
The reason is the electric motor produces a high, continuous torque over
most of it's power range. A gasoline engine produces a high amount of torque
over a small RPM range, and when you switch gears it produces a fraction of
the torque to the wheels. Torque is what moves a vehicle, and is related to
F=MA, where F = force, from the tires converting the torque to force, M =
mass of the vehicle, and A = acceleration.. Solving for A = F/M, so clearly
increasing the torque will increase the force, and thus the acceleration.
Torque: Something which produces or tends to produce rotation or torsion and
whos effectiveness is measured by the product of the force and the
perpendicular distance from the line of action of the force to the axis of
rotation.
http://www.acpropulsion.com/PDF files/Living with an EV.pdf - see
section 2.4, as it has a nice torque curve of a electric, vs gas. (BTW, if
the car had 200 hp of power on take off, that sloped line would continue up
to the y axis of the graph, so it's not using the full 200 hp until some
time down the road)
Are you talking about that messed up "tractive effort per vehicle weight"
graph?
What the hell is that?
"A gasoline engine produces a high amount of torque over a small rpm
range"???
Here are some _real_ engine dynographs
http://www.v8sho.com/SHO/dynographs.html
(I used to own a gen III V8SHO, what a fun car to drive!)
You can derive torque from HP and rpm, right?
<snip>
K. Jones
Jeff
instanses.
problem.
That is almost the entire problem - They don't say so.
There is one other thing about torque, which I will try to explain better
below.
*smile*
Exactly. Good time! I managed to get into the high 14's once with a 2.8 L
MPFI 5 speed Camaro. Those little engines really like a lot more fuel and
ign timing then when delivered stock.
imply that?
Just to show that that 275 HP is not used much! Same as the full (peak)
power of an electric motor.
duty??
There is a grammical error in there, but assuming you meant "wire a 20 HP
motor up for 60 to 80 HP", they, yes, that's what I mean. The motor can
handle that power for short duty cycles without damage, then backing it off
to the 20 HP level. This is easily done with PWM (Pulse Width Modulation)
techniques, which at full PWM duty cycle (duty cycle, as in the % that high
frequency electrical control pulses are on) is at full power. At 20% PWM
duty cycle, the motor is at approx 20% power. The controller is the key to
making this work. A AC motor using a simular setup just uses 3 PWM
controllers to generate the required 3 phase electrical needs.
Now your understanding what I'm trying to say :) "They" are not comparing
apples to apples.
in business.
A big chunk of those performance chips often suck! Some just tell the engine
it's running cold, and it goes into open loop operation with cold fuel
enrichment, screwing up the fuel injection system. All at a cost of $400 or
more, for a $4 chip. The other thing is it is set up to someone's test
engine, not your setup. Speed density systems (map sensor based) are very
sensitive to variations, unlike MAF based systems which are not that common
anymore due to expensive sensors. Of course there are exceptions, and most
brands seem to be getting better. I'd rather program my own to my engine and
parts, not someone else's "test" engine. check out www.diy-efi.org however
they experienced a huge crash a few months ago and are not fully up and
running again. Sorry for the off topic stuff - but you may enjoy it.
Exactly - the programming in both computers was compared to be the same, and
the dyno results showed very close HP ratings, but the Corvette was always
rated at least 15 HP higher (Not really that significant anyway at 285 HP +,
unless racing). The Corvette is much lighter anyway, which does make a huge
difference.
speed or load?"
Perhaps a bad choice of words - the torque of a electric motor (somewhat
dependant on motor design also) is VERY high at 0 RPM, and slowly decreases
with speed. This is perfect for accelerating a vehicle. With constant power
input, a torque curve output would basically look like a straight, sloping
down line on a graph of torque VS RPM. This is why that Tzero car can
accelerate faster then much higher powered cars. Torque is what moves a car,
the more you have, the faster you can accelerate ( Newton's law F = MA).
When bringing in RPM's with the torque, HP is produced.
What I meant (putting motor losses aside) when I said a electric motor is
always in it's peak power, was that if you dump 150 kW, or 200 HP into it,
you get 200 HP out regardless of speed, etc. When was the last time you saw
a gasoline engine start of at 0 RPM, and produce full HP until it's red
line? A general performance gasoline engine has a high power range in the
2500 to 5500 RPM range. It therefore needs to keep shifting into new gears
that bring the RPM's down, and thus the torque at the wheels. An electric
motor can produce full power (or close to it in reality) from 0 to 10,000's
of RPM's That is the difference with an electric motor and how a smaller
electric motor can beat a larger gas motor.
Because of this torque relationship, large diesel trains are not
mechanically powered! Large electric motors turn the wheels and a generator
is on the output of the engine!
acceleration.
rotation.
Yes, I'm well aware of the definition. See above, maybe I straightened it
out a little. Don't forget the wheels turn the torque into linear force.
Did I mention that it's HP limited due to traction problems?
graph?
The force that accelerates the car. Force is what matters in acceleration,
since A = F/M (rearranged F = MA). The torque is transformed into force
from the wheels. Smaller wheels = more force (at the expense of higher wheel
speed as the car speeds up). The distance from the bottom of the graph to a
line is proportional to the vehicle's acceleration.The electric motor is
accelerating at a constant rate when the traction control is on. When the
traction control is no longer needed, the electric motor is in a constant
power mode. With heavy, continuous acceleration, the total acceleration is
very high after several seconds. With the gas motor, acceleration starts off
slow, has a nice peak in the "power range" of the electric motor, then needs
to shift, greatly limiting the available torque at the wheels, and thus
greatly limiting acceleration.
range"???
Sweet! I always wanted something with a TPI 350 in it, now I want something
with a LT1 or LT4. With the performance of that Tzero, I may want to go with
electric soon!
Yes, and you can then turn the torque into force, if the drive train
reduction is known along with the wheel size. Wheel RPM, wheel size and HP,
or HP and speed would also work. Acceleration can be calculated from that if
the weight of the vehicle is given. Interesting they recorded the peak HP
much higher then the real peak. The HP peak does not count where the
transmission shifts and causes the stored up energy in the flywheel (shown
in the big dips) to be dumped all at once into the drive train, and thus the
spike.The net hp betwen the dip and spike is about equivalent to a
horizontal line, if that. The real peak is almost 50 HP lower then the
recorded peak HP because of this on the red line, first graph. I'm not sure
what those little spikes are from, perhaps a resonance in the air flow?
Steve Spence
not wrong. 500 watts of pv won't fit on an ev1, and though it would fit on a
full size station wagon, a full size wagon won't get 87Wh per km. Users
won't accept a 31km range either. The batteries would not live long with
100% discharge either. Like I said, a trickle charger. PV is not a mobile
technology, period.
Steve Spence
Renewable energy and sustainable living
http://www.green-trust.org
Donate $30 or more to Green Trust, and receive
a copy of Joshua Tickell's "From the Fryer to
the Fuel Tank", the premier documentary of
biodiesel and vegetable oil powered diesels.
Steve Spence
but it won't fit, and you are assuming 100% DOD and a 31 km range.
Unacceptable. A biofueled hybrid electric with a pv trickle charger is a
good goal, but not a pv powered ev. I stand by my claim, pv on cars are no
more than trickle chargers.
Steve Spence
