what should i do about computer rf emissions?
mugsby
Apr 13, 2006
80
sometimes i like to listen to am radio and i have a computer that has to be next to the radio, the problem is that when both are on the computer jams the radio. i also seem to have a problem with the power line acting as an antenna for both the radio and computer on top of that the power wiring for the house is all wrong but i don't own it so won't fix that. i put a scope on the line and watched some digital hash modulate every time the hard drive or cdrom started working, i put some snubbers on the computer power supply and bypass caps on the outputs and that help a little. then i tested my body to see what it was picking up, digital hash like crazy, same as what i can hear on the radio. so i used a function generator and a coil from a hard drive head to test if i could muzzle the rf, that worked ok, now i'd just like some ideas on how to stop it. btw, this has never happened before like this, some reason it's out of control  ???
ante1
Jan 24, 2004
4,136
Hi Guys,
Remember that no matter how good the shielding is made in the cabinet and the monitor, it will have no effect unless both units are properly grounded through their mains connectors!
Also for your own protection against magnetic field radiation these cores must be grounded!
mvs sarma
Feb 12, 2006
234
Hi
Take radio to a better location not in in vicinity of TV or computer or any device using SMPS and crystal oscillators.
audioguru2
Apr 6, 2004
12,022
People still use old AM radios?
An AM radio is an interference detector.
mugsby
Apr 13, 2006
80
i was thinking of building a linear power supply but i have to wonder about if just grounding a shield will be enough.
if you are in a sealed box and throw a tennis ball against one of the walls what happens outside of the box, thinking along those lines  ??? lol
