Hello guys
In the following link,
http://www.electronics-tutorials.com/amplifiers/negative-feedback.htm
the author speaks about how to made the necessary calculations to determine the transformer's turns ratio and also the LC needed for impedance matching a 50-ohm antenna to the preceding stage
Regardless of some of the details that the writer is talking about, espicially his talking about the dc biasing and the o/p voltage swing, I will focus in the discussion with you on the method of calculating the turns ratio.
Look at the fig:
the author said:
Here we are only mainly concerned here with the principle of a tuned circuit as a load. In this example we have a final load of 50 ohms connected to the output link coupling of our tuned circuit. Assume, just for discussion purposes, that in this example we needed a power output of 100 milliwatt from the amplifier and that we have available a power supply of 12V. Further,
Now:
2 * Po = [Vcc - Ve]^2 / R
or [2* 0.1] = [12 - 3.22]^2 / R
or [2* 0.1] = [ 8.78 ]^2 / R
and R = 77 / 0.2
= 385 ohms
Therefore the load presented to the output of our amplifier needs to be 385 ohms. The impedance ratio is 385 / 50 or 7.7:1 and the turns ratio on the transformer (inductor) is the square root of that number or 2.775:1.
My questions are:
1)Are these calculations are true in general?
2) Why '2' in 2.Po = [Vcc-Ve]^2/R, i learn that P = V^2/R
3)Why [Vcc-Ve]^2, I think it must be [Vcc-Vc]^2
Eagerly awaiting your reply
