What's the safe way to dispose of used copper etchant?
Andy
I've been using Ammonium Persulphate, the instructions just say to "Follow
your local authorities recomendations on disposal.".
Who is the local authority in Aus?
Just how toxic is the stuff - I'm thinking I'll just dig a hole out the back
and pour it in.
Alan Rutlidge
back
and pour it in.
Your local government (council) should be able to advise you on this.
Alternatively and probably better - consult your old high school chemistry
books and see if there is something you can mix with it to turn it into
something useful like Ammonium Sulphate which can be used as a fertiliser on
your plants. Any precipitated copper can then also be used as a trace
element. :)
Cheers,
Alan
David L. Jones
That would probably be your state EPA department.
and pour it in.
That's what I do for the small quantity I use. Although it would be
best to save it up and dispose of it at your local council chemical
cleanup day (if you have one). We had ours the other week and it was so
popular that there was an hour long wait to get in!
After using ferric chloride as a kid and hearing talk about not pouring
it down the sink, it was interesting to find out that Sydney Water
actually add it to our drinking water! Not that I drink tap water
anyway :->
Dave :)
swanny
and pour it in.
You could always evaporate it, and end up with crystals mostly of copper
sulphate and a bit of ammonium sulphate (if you've used the etchant a
lot). I have a few jars of big blue copper sulphate crystals as a result.
(Just) Allan
Or just add it to your drinking water - our government encourages
industry to use our kidneys to filter their waste flouride like this
every day.
Roy
This stuff is excellent for discouraging termites. Mix copper sulphate with an equal
quantity of calcium carbonate (crushed limestone) and mix with water (100g per litre),
pour it in small quantities (100ml per tree) round the base of your favourite trees and
termites will not trouble for at least a couple of years.
JD
Contact your local Council or EPA.
JD
with an equal
per litre),
favourite trees and
Rob
JD
About 5 yrs ago I contacted WA Water Authority asking about disposal, the
answer: Tip it down the sink with a heap of water behind it.
Sometimes we tipped it down the drain, some times it went out with lab waste
(at a cost of ~ $1/L).
We would have been generating 20 --> 30 L of spent solution per year.
rob
