What's this? (retroilluminated mobile phone screen)
Pajarico
Dec 28, 2006
18
Hi, I've savaged an old mobile phone (an LG, about 5-7 years old, I'm not sure really). There's a plastic sheet of yellow-greenish color behind the LCD which is for illuminating the LED
gsmaster1
Sep 13, 2003
72
Thats "EL foil Backlight"
These usually need a high voltage inverter to work
Pajarico
Dec 28, 2006
18
Thanks. Could you point me to a circuit that you know is working? Most of the high voltage inverters I found use some transistors and a transformer (I doubt there was a transformer in there).
EDIT: Now I have the name I'm doing a bit of research. Technicaly an EL panel is a capacitor which if has to be feed with a alternate sginal would make it a unpolarized capacitor. But wikipedia doesn't talk about inverting the DC and my panel is polarized....
The only thing that's clear is that it requires high voltage.
EDIT 2: Nevermind. It needs an inverter as you pointed out. I've found a manufacturer page with information:
http://www.seiko-precision.com.hk/html/el-catalogue.html
However I want to know how can I drive the panel without a transformer.... (cause there wan't none)
