to Ante, one remark, yes the FPGA is not a CPU, but .. i think is not very far from MCU. The princip is different, but in this moment in many FPGA application is used IP core for different procesor, and second, for FPGA is used program languages.
About this when you can use FPGA and when MCU. The question is very difficult, the FPGA or CPLD is a logic elemnt, and you can create many differents configuration between. The one of the best way is to combine logic and MCU, but in different case you can use mcu or fpga, actualy this is valid for complex procces. For example, if you want to have a SDRAM or DDR interface, but your CPU nt have this interface, the only ine way is using the CPLD or FPGA. If you have a need off fast respons and fast signal dating, i talk for a digital signal the logic is better, one of the advantage is the high frequency, and paralel processing. For exampel, if you have several different signal, and whant to make some datting, let this is sum betwen sygnal, for examlple A,B,C 4 bit bus, in FPGA or CPLD the output response is depend only from CPLA element delay, in this case around 10 ns, for CPLD, in to same case in microcontroler you must read different signal, after then make a sum, but this is not a parlel proces, you first read, A, after this read B, after this C, after this add A to B, after this add B to C, and finally put the result in to output, how you see this is many opperation, and if yu use the RISC cpu, at 20 Mhz, and 1 instruction for clock = 50 ns, the response time will be no less that 300 ns, if the cpu architecture can solve the problem with 6 operation.
The advantage of FPGA is that you can put CPU core in to chip, and combine it with other logic. Very good example is the car ECU, for good engine control, you must can control evry chanel searetly, if you have 6 cylinder engine, this is a 6 chanel for ignition, and 6 chanel for injection. Ok, good resolution is 1 uS, then you must have a 12 indipendent chanel, that can caontrol delay after some sync signal, and send impuls with some weidth. If you use CPU, this is not very easy, becouse you must look at 12 different timer, or counters, and compare it value to some variable. The CPU can do this, if CPU have several capture - compare modules, and you set some limitation on the sygnal condition, then you can make this. If you use logic, this is a very easy to be solved, you must put several counter and comparator, and this is all, you can use any resolution up to 10 ns, and you will have a 10 ns response time.
On the other hand, for this ECU you must calculate several parameters, delay and impuls weidth, if you use the FPGA for this, you must use IP core, but for this you must have a bigger FPGA, on the other hand every CPU canmake this calculation very easy, because this is not a very fast procces. And ... the result you have several way, to use cpu with many CCP modules, but this is not guaranty that all wil be OK, to use the big FPGA with IP core, this is a very good solution, may be more costly, or to use cpu and CPLD combination.
Another example is digital analisator, in this case you can't use the cpu, becouse you have a need off very fast response. But if you want to make some simple protocol converter, may be is better to use the CPU.
I can give you many different examples, but better is to understood what is the differents, and what is the advantage of the CPU and logic, FPGA or CPLD.
p.s. may be this is not very good english, and can't get the pulicer but i hope you will understood me.
