The 'Bus buffer' in the CV Keyboard diagram is making me think I need one
I see. Where did you suspect a need for the buffer?
sorry only seeing your reply now,An op amp buffer as in the circuit you showed is a good idea here. The impedance of your divider network varies quite a bit depending on which key is pressed. The buffer would lower the impedance and make it the same for all keys.
Would that not remove the specific impedance of the potentiometer/resistor for each key as well?
