Which leg is which for PNP power MOSFET IRF5305PbF?
seanspotatobusiness
Sep 11, 2012
193
I have PNP power MOSFETs called IRF5305PbF. The datasheet doesn't say which leg is which. Should it be obvious?
73's de Edd
Aug 21, 2015
3,730
Sir seanspotatobusiness . . . . .
WHUT you taklin' 'bout . . . . . . . . . . Willis ?
Whut you gonna do . . . . . .wire this up to a "tater " eye incubator ?
Notice that it has 2 drain connections ∴ you could change out the cooling oil in a HURRY on that sucker !
73's de Edd
My wife and I always compromise . . . How? . . . “I admit I am wrong and she agrees with me!”
seanspotatobusiness
Sep 11, 2012
193
Thanks very much. It was for a project to light a green LED whenever my ESD grounding point is connected to ground but it turns out that neither a transistor nor MOSFET is suitable (a MOSFET even less so because it lights up when I touch the probe without a need for two connections to ground).
Do you think it's sketchy to connect my PSU ground to earth for this? The PSU will be a PC PSU and used to power a few other pieces of equipment (network switch, Raspberry Pis, label printer). Originally I was advised to use a "high side" circuit but they're too sensitive and light the LED even when the connection to ground is poor.
14,317
The ESD grounding point is usually connected to earth potential using a resistor in the MΩ range. The explanation is e.g. here.
The circuit in your link may be suitable when you replace the NPN by a MOSFET. You'll have to add a resistor from gate to source to reduce sensitivity to small charges (as you have noticed). Also a series resistor and a zener diode to protect the gate from overvoltage are advisable. Hre's a rough sketch:
Cannonball
May 6, 2017
193
73's de Edd
Sir that is real diplomacy!
