Drew Cutter
- Jan 1, 1970
- 0
I need some help figuring out what type of micro hydro system I need and
which mfg. to go with . Thanks. To be used for the house.
Drew Cutter said:I need some help figuring out what type of micro hydro system I need and
What is cfm and afm ?SQLit said:pretty hard to do with out specific information about the water source you
have.
cfm's or afm
How do you figure out how much power ? The square footage of the house ?Head?
amount of power you want?
Drew said:I'm thinking of using micro hydro for a new built home , so i don't
have clue on the amount of kWh. What would be a good average for family
size home ? The property has a creek (looking to buy). Good amount of
rain fall in the fall and spring. 3 inches of rain a month , during the
fall and spring. From the map it looks like the source is a combination
of mountain and rainfall. The property is flat if this make a
difference. I don't have clue as which mfg. to go with once i have the
data to choose. reliability , repairs , etc . Thanks.
Drew Cutter said:I'm thinking of using micro hydro for a new built home , so i don't
fall and spring. From the map it looks like the source is a combination of
mountain and rainfall. The property is flat if this make a difference. I
don't have clue as which mfg. to go with once i have the data to choose.
Drew said:The reason for building a dam is for when you are in dry season or low
water flow times ? If the source of the water is from the mountains and
the land isn't that far from mountains . Wouldn't the flow be ok most of
the time ?
In building a dam , couldn't just use very large boulder creating a
means of diverting the water , for a water fall ? How big of a dam would
you need to get adequate power ?
Drew Cutter said:What is cfm and afm ?
Drew Cutter said:The reason for building a dam is for when you are in dry season or low
the time ?
the time ?
In building a dam , couldn't just use very large boulder creating a means
of diverting the water , for a water fall ? How big of a dam would you
Gìmmìe Bob said:There "incredibly smal head" mans at least 10 feet high.
